Runout reduction revisited
A project log for Minamil 2dc: a minimal CNC mill
Each axis: ̶$̶5̶ ̶$̶8̶ $10 motor+lead screw, 3x LM6UU, 3x 6mm x 100mm rod, 1/8in hardboard, PC case screws
paul-mcclayPaul McClay 05/18/2022 at 02:150 Comments
Poorly controlled runout has haunted this project since first musings about its silly predecessor. Pulling back from an earlier somewhat helpful idea seems to have helped to escape a local maximum. At least for parts that can be finished with a single tool.
To prove the pudding, an even smaller differential gear set   ̶i̶n̶ ̶p̶r̶o̶g̶r̶e̶s̶s̶.̶.̶.̶   done:
Or, if you have a few minutes worth of curiosity to see reduced runout at work:
I   ̶p̶r̶o̶l̶l̶y̶ ̶s̶h̶o̶u̶l̶d̶  eventually did add something  ̶h̶e̶r̶e̶  there about reducing runout with cheap dremeloid clones...
Already kinda glossed the method in this log. The main thing since then is just getting better at getting more predictable results with less effort. Also I partially undid an earlier attempt to constrain the poorly constrained collet, which made it easier to just push it around until it points in the right direction.
The "in progress" pic that this log entry started with:
Done with a cheap generic DremelⓇ-like rotary tool.
