Metal!
A project log for Minamil 2dc: a minimal CNC mill
Each axis: ̶$̶5̶ ̶$̶8̶ $10 motor+lead screw, 3x LM6UU, 3x 6mm x 100mm rod, 1/8in hardboard, PC case screws
paul-mcclayPaul McClay 08/20/2020 at 11:200 Comments
Didn't hit any fundamental problem.
Lost a (haphazardly attached) anti-backlash nut on the first pocket.
Ran progressively deeper cuts in second pocket until hold-down clamps slipped. Vid shows penultimate pass. Hold-downs are limited because I don't have enough nuts to populate all the embedded nut positions under the spoil board.
Oh yeah, replaceable spoil board and integrated work holding.
