A couple logs back concluded with:
Next up: is Z hysteresis small enough to run paths with varying Z vs a succession of descending waterline paths?
(i.e. parallel finishing)
Yes.
The second pocket has other issues, but this isn't about that.
A project log for Minamil 2dc: a minimal CNC mill
Each axis: ̶$̶5̶ ̶$̶8̶ $10 motor+lead screw, 3x LM6UU, 3x 6mm x 100mm rod, 1/8in hardboard, PC case screws
Yes.
