To fork or not to fork? (will try to not)
A project log for Minamil 2dc: a minimal CNC mill
Each axis: ̶$̶5̶ ̶$̶8̶ $10 motor+lead screw, 3x LM6UU, 3x 6mm x 100mm rod, 1/8in hardboard, PC case screws
paul-mcclayPaul McClay 08/19/2021 at 15:410 Comments
I’ve entered “this” project in competition for the HaD Prize. But not this project because contest entry requires a project created after the start of the entry period. So entry requires a new project. But simply cutting over to a new project would cut off everyone who chose to follow (thank you!) this one for an artificial reason. So I’m thinking of continuing to log development here and make the new project a contest-oriented presentation of material from here. If the HaD Prize crew accept the idea.
