Z v3 -- counterweight delete -- progress
A project log for Minamil 2dc: a minimal CNC mill
Each axis: ̶$̶5̶ ̶$̶8̶ $10 motor+lead screw, 3x LM6UU, 3x 6mm x 100mm rod, 1/8in hardboard, PC case screws
paul-mcclayPaul McClay 08/17/2022 at 22:060 Comments
From last week's episode...
The result is surplus torque and steps/mm, so the next rev can use a larger diameter to get more (all?) of the string wound onto the drum in a single helix of more nearly uniform diameter. Currently the steps/mm changes when the string fills the (thin) drum and winds back over itself [...]
So... yes.
Z v3.01
In this iteration:
(...and that little screw on the right frame side -- for stowing the counterbalance rig -- can go away now)
While assembling this rev I made a short list of minor tweaks for one more iteration that should be ready to share (because optimism).
