關閉
L2 Camera
Fully manual twin-lens reflex instant film camera
值得關注的相似專案
Not a nice camera: it requires both patience in assembly and a sufficient skill set in photography, and you will need to make difficult choices about environmental pollution.
I created L2Camera, because I had not found an Instax camera, that works for me. Later, I realized that with this project I can reduce the amount of photo-waste in two ways. Firstly, by re-using existing, but out-of-use photo equipment. Secondly, by giving photographers a tool that creates images of higher quality and leaves less discarded shots, which go to landfill.
To build your own L2Camera you'll need:
  1. find a donor Lubitel camera and a Kiipix/Printoss printer
  2. have a 3D printer and approx. 25 meters of PLA filament
  3. print the 3D model
  4. adjust the front panel to the viewfinder lens
  5. assemble the camera body
  6. align the lens
  7. assemble the whole camera
L2Camera Body Parts.stl
L2Camera body parts prepared for 3D printing
Standard Tesselated Geometry - 2.00 MB - 12/10/2020 at 19:08
下載
  • 1 × Developer Unit Threre are several options to choose from. My current prototypes use parts from Kiipix "printer"
  • 1 × Lubitel TLR camera A tired Lubitel camera which can be easily found in Eastern Europe
  • 1 × 3D printed camera body See the Files section
  • Maker Faire Pilsen
    Vladimir Gorshenin • 06/22/2021 at 07:54 • 0 comments
    Pilsen city, famous as the place where lager beer was invented, hosted a Maker Faire event in the beginning of June. L2Camera project was selected for this first after-the-lockdown event!
    There were many makers showing their projects and crafts. My attention was caught by a project by Vaclav Mach (aka xx0x), the author of gbpxl (GameBoy Printer XL).
    Vaclav showed  talking wrist watches and a table clock. I liked these projects because they are done very thoroughly. He went even that far to reach out to Vaclav Knop, a Czech actor and director, whose voice was used for all railroad audio announcements across the country. Mr. Knop kindly agreed to record voice announcements again specially for the watch project.
    The camera attracted attention and, surprisingly enough, I even got price quotes from the visitors!
  • Final touches
    Vladimir Gorshenin • 05/07/2021 at 07:47 • 0 comments
    Having spent decent time not only designing the camera, but also using it, I believe, I've developed the sense of control of it. Now I get photos exactly as I saw them. And the recent series would be an example.
    I consider the design to be final. There were a couple of things I wanted to improve though.
    There was a rectangular slot near the viewfinder - the legacy from Kiipix. A spirit level nicely fitted into the hole.
    L2Camera features
    A spirit level fitted nicely to a slot near the viewfinder
    I designed the tripod socket of 3/8" size. I had two reasons for that. Firstly, I doubted that a 3D printed screw thread would be strong enough to hold the camera, and I chose the bigger thread size. Secondly, I had only a 3/8" tripod on hand to test the design.
    L2Camera features
    A 1/4" to 3/8" metal adapter installed to the thread hole
    Later I received comments that the 3/8" screw thread is inconvenient. I solved the problem by installing a metal adapter. The whole assembly works fine.
  • Flash Mode
    Vladimir Gorshenin • 05/01/2021 at 19:08 • 2 comments
    An ideal scenario for party or reporter mode - is when one can (almost) forget about manual controls of the camera. The following setup does it.
    What I particularly like about the L2Camera design is the ability to combine it with the existing photo gear. The picture below shows one of the L2Camera prototypes with an external handle and an automatic flash unit attached. A remote release cord is used for convenience.
    L2Camera with an external flash attached
    L2Camera in flash/party/reporter mode
    Lubitel shutter, thanks to its design, can be used with flash on any speed. Even a flash unit which is not powerful enough, combined with Instax high ISO film, together can easily give small apertures, like f/11, f/16. These apertures, in turn, provide large depth of field - and the photographer can be less worried about precise focusing.
    My recipe for indoor party/reporter mode with L2Camera and flash is:
    1. set shutter speed to 1/30 or 1/60
    2. use an automatic (computer) flash unit and set it to ISO 800
    3. set focusing distance  to 2.8 m
    4. set aperture according to the distance and the settings of the flash (it should be around f/8.0 or f/11)
    5. use the frame viewfinder (as in the photo above)
    6. point and shoot!
    With these settings L2Camera works almost the same way as conventional Instax camera: fixed focus, fixed aperture, frame viewfinder and automatic flash.
  • Spring photos
    Vladimir Gorshenin • 05/01/2021 at 18:31 • 0 comments
    Would like to share some photos I took with the P12 prototype.
    The first five shots were taken on a sunny day. Instax film has ISO 800, according to the Sunny 16 rule I should use f/16 aperture and 1/800 speed. But Lubitel shutter provides speeds up to 1/250. Even if I use the smallest aperture provided by the lens f/22, then the speed should be 1/400, which is almost two times faster then the shutter offers. In other words, sensitivity of Instax film was too much for the lightning conditions. I decided to compensate excess of light by taking pictures against sun light. It gave an effect of +1EV or +2EV.
    A photo made with a L2Camera
    A hidden place near Petrin hill in Prague
    A photo taken with a L2Camera
    A steep path to the top of Petrin hill in Prague
    A wall under direct sunlight
    A tree in blossom
    Juicy spring grass
    Below is a set of photos taken with monochrome Instax film on a cloudy day.
    Swans on Vltava river in Prague
    An unexpected multi-exposure photo
    Prague under lockdown - no turists
    Prague under lockdown - empty visitor's center
    The Old Town Square - unusually empty
  • Giving away camera bodies
    Vladimir Gorshenin • 04/14/2021 at 06:28 • 0 comments
    L2Camera Early Prototypes
    I have a bunch of camera body prototypes printed to validate the design of L2Camera. Would like to trade these for a coffee to those who are interested in building their own L2Camera. Buying an existing camera body saves your time, creates no additional plastic waste and frees up my place. Please have a look at my postings on Tindie: https://www.tindie.com/stores/2ndlife/
  • The project is grabbing attention worldwide
    Vladimir Gorshenin • 01/26/2021 at 12:22 • 0 comments
    L2Camera project drew attention twice right before the Christmas 2020.
    Keigo Moriyama reviewing a L2Camera
    One of the camera prototypes had traveled half of the globe from Prague to Tokyo, where Keigo Moriyama, an Italian photographer living in Japan, made the first review of a L2Camera. In the review you can spot the same camera body that was printed and assembled in the course of writing these log entries.
    Keigo has kindly shared with the project the photos he took during the review session. Here they are.
    The first scene at 3:40
    A photo by Keigo Moriyama taken with a L2Camera
    The second scene at 3:48
    The third scene at 3:58
    The fourth scene at 4:06
    A photo taken with a L2Camera, by Keigo Moriyama
    The fifth scene at 4:14
    The sixth scene at 4:22
    The seventh scene at 4:30
    The eighth scene at 4:39
    The ninth scene at 4:47
    The tenth scene at 4:56
    Also, Keigo provided technical feedback. He suggests adding a cold shoe mount and switching from 3/8" tripod thread to 1/4". According to Keigo, a cold shoe could carry additional equipment like a like meter, and 1/4" tripods are more common now.
    The project took part in Maker Faire Rome 2020 virtual event. It was both interesting and challenging to show case the project through a virtual stand while sitting at home in reality.
    L2Camera exhibited on Maker Faire Rome 2020
  • Assembling the camera body
    Vladimir Gorshenin • 01/19/2021 at 12:32 • 0 comments
    To assemble a L2Camera body the following components and tools are needed:
    Components and tools needed to assemble L2Camera body
     First step - index pins
    There three round holes on the rear surface of the front panel and three their counterparts on the front surface of the main part. Check that filament goes easily into the holes. If not, adjust the holes with a sharp an narrow tool. Then glue in PLA pieces into holes of the main part, and cut filament 2 mm above the surface. You got register pins to facilitate alignment of the camera body parts. Now put the main body part on a horizontal surface with the pins on top and then put the front panel above the main part, align both parts with the register pins, join the parts together and check that there is not gap between them. If there is a gap, shorten the pins and check again.
    Adding register pins to facilitate alignment of the camera body parts
    Register pins glued in and trimmed to 2mm height
    Second step - gluing the parts together
    Now put again the main body part on a horizontal surface with the pins on top. There are four rectangular pads on the main body part and four their counterparts on the front panel. Apply glue to the pads on the main body part. If you printed the model with brims, them apply some glue to the brims at the edge of camera body - that will create a better looking seam. Now put the front panel above the main part, align both parts with the register pins - start with the pin near the main lens hole and then proceed with the pins near the viewfinder lens hole. Join the parts together and apply some force for approx. 10 seconds to form a tight joint.
    Two part of the camera glued together
    Third step - post-gluing finishing
    If you printed with brims, remove them with an utility knife.
    Post-gluing processing - removal of brimsPrepare the tripod mount part - remove the brim if you printed with brims - then slide in the socket part into the hole at the bottom of the main body.
    Tripod mount with the brim removed
    Post-gluing processing - attaching a tripod mount
    L2Camera body with a tripod mount attached
    The result
    A L2Camera body after assembling
    L2Camera body attached to a Kiipix developer unit
    L2Camera body attached to a Kiipix developer unit, bottom view
  • Adjusting front panel to the viewing lens
    Vladimir Gorshenin • 01/19/2021 at 12:31 • 0 comments
    L2Camera front panel is designed to be adjusted to the particular viewfinder lens of the donor Lubitel camera. For that reason, the 3D model has the screw thread which is tighter than necessary. The adjustment procedure requires you to widen the thread by applying heat to it.
    You need:
    • a L2Camera front panel printed with PLA
    • a Lubitel viewfinder lens (the top one)
    • a 1.0 mm flat screwdriver
    • a source of warm air (approx. 50C/120F) - a hairdryer works best
    Steps:
    1. check that the lens screws in into the front panel tightly, if not - if it goes loosely - please report to me.
    2. unscrew and release the lens block (glass) from lens rim by undoing the stopping screw on the rim - you'll get the aluminum lens rim without glass
    3. screw in the rim into the front panel as deep as it possible, but don't apply to much force
    4. warm up the rim screwed in into the front panel with warm air by applying it to the inner surface of the rim only. Try not no heat other surfaces of the panel
    5. screw in the rim a bit further and let the whole assemble to cool down
    6. check if the rim screws in and out completely, smoothly and without backlash; if it doesn't then repeat the step 3
    7. put the lens block back into the rim and secure it with the stopping screw.
  • Printing the camera body
    Vladimir Gorshenin • 01/14/2021 at 16:44 • 0 comments
    After releasing the 3D model, I'd like to share my recommendations on printing the camera body. Before printing, please consider my notes regarding printer selection.
    The 3D model is designed to be printed with:
    • PLA filament (please refer to my considerations on filament)
    • a 0.4 mm nozzle and 0.2 mm layer height
    • two perimeters, no supports
    • the infill value of 5% (it's enough)
    • any kind of infill pattern, please consider Gyroid
    If your printer doesn't have PEI surface, I highly recommend to add a 5 mm brim to increase adhesion of plastic and prevent warping.
    The STL file contains the following four parts:
    1. the front panel
    2. the camera body itself
    3. the tripod socket
    4. the light-blocking insert, optional
    I recommend to print the parts in the same sequence. Print the front panel and check that the Lubitel's viewing lens screws in tightly. It can be even very tight - that is expected, that is by design. Later, during assembling, this issue will be fixed and the lens will match the thread perfectly. If the lens fits loosely, please report this case to me.
    Next, print the camera body and the tripod socket. Print the last part, the light-blocking insert, only if the previous parts are not opaque enough. You can print the insert with any PLA filament and paint its internal surface with 3-5 layers of black acrylic water-based paint.
  • Releasing the L2Camera 3D model
    Vladimir Gorshenin • 12/10/2020 at 19:35 • 0 comments
    After half a year of prototyping the project came to a point, when it's ready to be shared with a broader audience. The STL file with camera body part is available now!
    I used OpenSCAD software to design the camera body. I made the model many parameters to have it adjustable.
    To facilitate printing I divided the model into three parts: the front panel, the middle part and the tripod socket.
    The rear panel contains a recycling sign identifying filament.
View all 19 project logs
分享
討論
Steven 撰寫 09/19/2024 at 09:02 • point
I just found out about this, have ordered a camera and print thing, downloaded the files and am now waiting on delivery.
  您確定嗎? 是 | 否
Steven 撰寫 09/24/2024 at 08:49 • point
update, the Lubitel 2 has came, cleaned lenses , timer is needing some lubricant, seems to be performing well apart from timer and mirror needs a cleaning.
  您確定嗎? 是 | 否
Vladimir Gorshenin 撰寫 08/14/2025 at 08:36 • point
Hi @Steven thank you for sharing! How is your progress? Would you need any assistance with it?
  您確定嗎? 是 | 否
Glenn 撰寫 11/18/2021 at 18:24 • point
I am so beyond excited to discover this project, I have been infuriated by the lack of full manual Instax cameras but was too intimidated by engineering focal distances to attempt my own build. Thank you for supplying this incredible information! I have just ordered the doner components and can't wait to get started on making my own L2. Is there any chance you would be willing to share step data for the camera body instead of just STL? Thank you SO MUCH for all your work and sharing it with the community!
  您確定嗎? 是 | 否
nemrod153 撰寫 08/03/2021 at 10:29 • point
hello, this looks like an interesting project. i've yet to meddle with instax film, but i tried diy-ing my own lubitel, and hit a barrier. how did you manage to accurately measure the flange distance? there seems to be no data about it online
  您確定嗎? 是 | 否
Vladimir Gorshenin 撰寫 08/25/2021 at 07:56 • point
Hey nemrod153, thank you for reaching out. Could you please elaborate, what distance are you trying to measure and what specific Lubitel camera model do you work on?
  您確定嗎? 是 | 否
Giles 撰寫 06/10/2021 at 12:54 • point
Hi Vladimir,
Just made an L2... works like a charm.
Thanks for sharing
Giles
  您確定嗎? 是 | 否
Vladimir Gorshenin 撰寫 06/14/2021 at 18:20 • point
Hi Giles, I'm glad to hear that! Thank you for sharing.
  您確定嗎? 是 | 否
Lukas 撰寫 12/29/2020 at 21:44 • point
Hi, I am about to print the kit. How many perimeters and layer height do you recomend?
  您確定嗎? 是 | 否
Vladimir Gorshenin 撰寫 01/14/2021 at 15:34 • point
Hi Lukas, thank you for your interest in the project! I'm working on a "how-to-print" post. Please wait for the end of this week, I'm going to publish it soon.
  您確定嗎? 是 | 否
Vladimir Gorshenin 撰寫 01/14/2021 at 17:07 • point
Lukas, the instruction on printing is ready. Please find it in the logs section.
  您確定嗎? 是 | 否
Vladimir Gorshenin 撰寫 12/12/2020 at 09:12 • point
The first release of the 3D model is available now! Please refer to the Files section
  您確定嗎? 是 | 否
Vladimir Gorshenin 撰寫 11/05/2020 at 08:11 • point
The files will be published soon. I'm finishing proof prints with one more 3D printer model to check that everything gets as it should. An Ender 3 now.
  您確定嗎? 是 | 否
Keigo Moriyama 撰寫 11/04/2020 at 04:57 • point
are there any available files?
  您確定嗎? 是 | 否
