Final touches
A project log for L2 Camera
Fully manual twin-lens reflex instant film camera
Vladimir GorsheninVladimir Gorshenin 05/07/2021 at 07:470 Comments
Having spent decent time not only designing the camera, but also using it, I believe, I've developed the sense of control of it. Now I get photos exactly as I saw them. And the recent series would be an example.
I consider the design to be final. There were a couple of things I wanted to improve though.
There was a rectangular slot near the viewfinder - the legacy from Kiipix. A spirit level nicely fitted into the hole.
L2Camera features
A spirit level fitted nicely to a slot near the viewfinder
I designed the tripod socket of 3/8" size. I had two reasons for that. Firstly, I doubted that a 3D printed screw thread would be strong enough to hold the camera, and I chose the bigger thread size. Secondly, I had only a 3/8" tripod on hand to test the design.
L2Camera features
A 1/4" to 3/8" metal adapter installed to the thread hole
Later I received comments that the 3/8" screw thread is inconvenient. I solved the problem by installing a metal adapter. The whole assembly works fine.
