Bearing margins
A project log for Propel-E 450 | A very powerful windturbine
A 2m windturbine made from corn! Completely 3D-printable and open-source.
bram-peirs-fw2wBram Peirs @ FW2W 10/03/2020 at 17:190 Comments
For now we had a little play on the margin between the bearing and the generator. The reason for this is that diameter of the hole for the bearing can vary a few tenths of a mm, depending on how much glue is used. Therefore we designed a custom piece that can be printed in one part so that it always will fit perfectly. It is shown below in purple:
The bearing is placed into the part like this:
And afterwards both are welded into the generator. It's also possible and maybe even better to wait to insert the bearing until the holder has been welded into the generator:
