Another 3D Printer Enclosure
Documenting my crazy idea of making a fire resistant enclosure out of Aluminum and tempered glass.
Public Chat
A gray-headed electrical engineer ventures outside his comfort zone by building a sturdy enclosure for a Ender 5 Pro 3D printer. This project has gone from "how hard could it be" to "I may have bitten off more than I can chew". But success is in sight. I made a test door panel to prove the concept (see gallery). All the hardware pieces have arrived, and the extrusions and glass panels will arrive next week. Drawings are 75% complete, and will include DXF, OpenSCAD, and a spreadsheet BOM, including a rambling narrative with photos.
Check the repo for the design details where I've updated notes about the design and some of the decisions.
cage-panel.pdf
Engineering drawing of the basic frame/panel, which is the building block of the design. DWG and DXF files can be found in the repository.
Adobe Portable Document Format - 182.84 kB - 09/02/2020 at 00:59
Preview
Download
cage-bom.xlsx
BOM (updated 01-Sep-2020, see project logs)
sheet - 32.66 kB - 09/01/2020 at 12:08
Download
  • 4 × FN201, Extrusion, 2020 Al, 230 mm
  • 2 × FN202, Extrusion, 2020 Al, 410 mm
  • 48 × Nut, 2020 Tee-slot, SS, M4
  • 36 × Corners, Right-angle, Al, for 2020, 60 mm, 5-hole for M5
  • 4 × FN 203, Extrusion, 2020 Al, 460 mm
View all 21 components
  • Design Details Updated, Video Soon
    TheStumbler09/07/2020 at 10:55 0 comments
    Added some design details to the repo.  Been working on an exploded view render from OpenSCAD.  Should have it ready tomorrow.  Work and  a nearby typhoon delayed final assembly of the cage another day or two - that's life.
  • Panels a Plenty
    TheStumbler09/05/2020 at 09:11 0 comments
    Built up all the glass panels today.
    I'll begin the final assembly tomorrow.
    Also updated the repository with a final assembly drawing and made a few BOM corrections.
  • A $30 Typo
    TheStumbler09/01/2020 at 12:07 0 comments
    As I started to assemble the first panel tonight, I found yet another mistake.  I ordered two of the larger panels incorrectly. In this case, it was an error when I rolled up the various Parts Lists into a to-purchase BOMs.  It was an extremely unlucky typo - neither of the two panes were the correct size.
    Ordered:
    • 2 ea 640 x 470 mm panes
    Needed:
    • 1 ea 670 x 470
    • 1 ea 670 x 570
    I will plow ahead building what I can, new panes on order, should arrive before Friday if I'm lucky.
    Repo updated with revised BOM.
  • Project Repository Goes Live
    TheStumbler09/01/2020 at 04:41 0 comments
    Did some cleanup of the files and organization, pushed a project repository on GitHub.  This repository includes some more photos (I think I've maxed out the gallery space on Hackaday.io), the OpenSCAD files, and a 2D CAD drawing ( DWG, DXF, and PDF) of the panel.  The panels form the basic building blocks of the design.
    Yet to do, documentation-wise:
    • complete and upload the final assembly drawing
    • notes and comments on the design
    • explanation of some of the OpenSCAD craziness
    As for the enclosure, the remaining six rails of the correct length will arrive today. I will start assembling everything tonight.  I should have it assembled and running by the weekend, knock on wood.
  • Incoming Inspection
    TheStumbler08/30/2020 at 08:02 0 comments
    Almost all the remaining parts arrived Friday.  A bundle of cut-to-length 2020 profiles, and the tempered glass panels.  See gallery.
    Despite triple checking my numbers, I mis-ordered on length of profile, requesting 630 instead of 650mm.  Corrected pieces ordered Saturday, should get here Monday or Tuesday.
    Incoming Inspection, Profiles
    I also had one heck of a time with gasket materials to keep the glass securely in place.  As you will see (when I finally upload my drawings), I had a careful plan that a pair of 3mm gaskets with circular cross-sections would be perfect.  Alas, it proved to be a bear to install them.  First problem was how to install the gaskets.  I basically had two cylindrical rubber "ropes" that I had to squeeze in between the glass edges and the insides of the 2020 profile.  This was proving to be quite awkward.  The second problem was even when I had only one gasket installed, the force required to bring the frame corners together was scary.
    In the end, I decided this idea was overkill.  Unlike ordinary gaskets on windows, whose goal is to prevent leaks, in my application the main function is to just keep the glass from rattling in the frame.  I pulled most of the gasket material, and just left a short pieces along each edge.  Problem solved.
    This discussion might be getting ahead of myself, since I still haven't posted drawings yet, but you can get the idea of the problem from this sketch above and picture of the test panel in the gallery (that test panel didn't have any gasket, and taught me that I needed one).
  • The Fun Begins
    TheStumbler08/26/2020 at 12:07 0 comments
    I've been curious for some time about 3D printers, but never took the plunge until the virus hit.  Back in March, a friend of mine pointed out that he was making miniature people, cars, and buildings for his HO-gauge model railroad layout using a $300 printer from China.  I knew the time had come.  His model was the Ender 3, but I splurged and got the Ender 5 Pro.
    Shortly after receiving my new printer, another friend told me I needed an enclosure, advice that I kept putting off until I realized he was right.  After doing a little research, I wasn't really impressed with any of the off-the-shelf solutions.  Having an enclosure that was not flammable seemed to be desirable, but many of the popular ones weren't.  Building my own seemed an option, but I imagined complex 3D pieces to join panes of glass together at the corners began to worry me. And any "good" enclosure needs doors, panels, mounting points for accessories, etc.
    Then suddenly, I had an idea ... use the same type of aluminum extrusions that comprised the 3D printer as frames for a glass enclosure. and it seemed much more approachable.  This hack page will force me to document my project, and hopefully nag me to wrap it up sooner than later.
    The main design is locked in.  I was a little worried about a few educated guesses I made in the design, so I built a small test panel.  Surprisingly, everything went together as expected.  The only tweak was one I had planned for, that was selecting the type and size of packing to keep the glass from rattling in the frame.  I have all the hardware in-hand, and pulled the plug on the extrusions and glass panels yesterday.
    I have a substantial part of the documentation already completed.  This includes a BOM, with part information and data sheets, and CAD drawings in DWG/DXF format (assembly drawings) and OpenSCAD for 3D modeling and exploded view animation.  I'll try to post an update every couple of days until it's all built and in-service.
View all 6 project logs
