As I started to assemble the first panel tonight, I found yet another mistake. I ordered two of the larger panels incorrectly. In this case, it was an error when I rolled up the various Parts Lists into a to-purchase BOMs. It was an extremely unlucky typo - neither of the two panes were the correct size.
Ordered:
- 2 ea 640 x 470 mm panes
Needed:
- 1 ea 670 x 470
- 1 ea 670 x 570
I will plow ahead building what I can, new panes on order, should arrive before Friday if I'm lucky.
Repo updated with revised BOM.
TheStumbler
