How to tweak your camera settings
A project log for Raspberry Pi 0 HQ USB Webcam
Raspberry Pi 0 W + High Quality Camera = High-quality USB Webcam!
huan-truongHuan Truong 08/27/2020 at 00:310 Comments
For debugging, a 115200 baud serial interface is provided as a ttyACM device:
Also, there is a untested serial interface on the serial 40-pin header: https://pinout.xyz/pinout/uart
If you want to modify the image content the quick-and-dirty way (not recommended):
Tweaking your camera settings
After you get into the pi by the debugging ttyACM interface, you'll see:
# cat /opt/uvc-webcam/start-webcam.sh
#!/bin/sh
/opt/uvc-webcam/multi-gadget.sh
/usr/bin/v4l2-ctl -c auto_exposure=0
/usr/bin/v4l2-ctl -c auto_exposure_bias=15
/usr/bin/v4l2-ctl -c contrast=0
/usr/bin/v4l2-ctl -c video_bitrate=25000000
/opt/uvc-webcam/uvc-gadget -f1 -s2 -r1  -u /dev/video1 -v /dev/video0
Now, you can change the v4l2 parameters on the fly and preview their effects on your camera output.
To get the list of tweakable parameters:
# /usr/bin/v4l2-ctl -L
This is how I tweaked the settings for V1.1. I think it's possible to squeeze even more performance out of this camera.
