KuttyPy
Learn Microcontrollers with Python - A new look at bootloaders
Public Chat
The kuttyPy (/kʊtipʌɪ/) Microcontroller training utility allows real-time manipulation of the registers in microcontrollers via a connected computer containing its python library. setReg and getReg function calls act as a real-time debugging and monitoring utility, and combined with Python's visualization and analytical utilities, this approach has immense pedagogical potential for beginners. It is also a built-in troubleshooting tool for your microcontroller projects
The kuttyPy hardware is an ATMEGA32 microcontroller development board developed by the ExpEYES project, and is currently supported by this software. It contains the kuttyPy firmware, but can also be used to run other programs via its bootloader.
It can be used as a basic test and measurement tool, and also has a (rather primitive) android app.
We've all struggled with troubleshooting microcontroller projects
- Probing individual IO pins with a multimeter
- Measuring voltages from analog sensors before implementing ADC dependent logic
- Replacing digital(I2C) sensors because you suspect they're incommunicado, and don't have an oscilloscope at hand
... and so on
The KuttyPy approach fixes that for you by being a more powerful bootloader that also acts as a debugging utility, and comes with a powerful companion graphical app.
Screenshot
The kuttyPy hardware is an ATMEGA32 microcontroller development board developed by the ExpEYES project. The hardware contains the kuttyPy firmware, but can also be used to run other programs via its bootloader functionality. The software is being extended to support other microcontroller platforms as well, such as the 328p found on Arduino Nano boards.
setReg and getReg Python function calls act as debugging and monitoring tools, and combined with Python’s visualization and analytical utilities, this approach has immense pedagogical potential for beginners to the microcontroller world.
Head over to the links on the project homepage for complete docs, or visit the Website Link
Lighning Talk delivered at Scipy.in, IIT B : https://static.fossee.in/scipy2019/SciPyTalks/SciPyIndia2019_S010I_Lightning_Talk_09_20191130.mp4
An example of basic Python based interaction:
from kuttyPy import * #Import the library. also automatically connects to any available kuttypy hardware.
setReg('DDRD',160) #0b10100000 PD7(BLUE LED) and PD5(GREEN LED) made output type
setReg('PORTD',160) # PD5 and PD7 set to HIGH. Both LEDs start glowing
Please note that Python code is not executing on the uC itself. The uC merely has a state machine to manipulate registers based on input received from a computer/laptop/phone running an appropriate app.
This approach was extrapolated to build a full fledged graphical interface with Qt, to control all the features of the Atmega uC .
The simple Atmega32 processor is now capable of the following:
  1. You can monitor every input
  2. Toggle every output
  3. Deal with Peripherals such as PWMs and Counters
  4. View ADC readings via an analog gauge
  5. Scan for sensors connected to the I2C Bus
  6. Monitor readings from sensors [TSL2561 luminosity, and MPU6050 IMU supported]
What can I use it for?
  • It’s an atmega32 development board with a bootloader supporting the ‘arduino’ protocol
  • The bootloader also allows real-time manipulation of registers through commmands sent via the serial port.
  • This is done by the associated Python library and companion GUI
    • You can monitor every input
    • Toggle every output
    • Deal with Peripherals such as PWMs and Counters
    • View ADC readings via an analog gauge
    • Scan for sensors connected to the I2C Bus
    • Monitor readings from sensors
  • Compile code to hex with the avr-gcc compiler
  • Upload hex via the built-in uploader
  • Rapidly prototype and debug educational projects. For example, you can verify ADC input values before handing over control to the uploaded hex file which will likely have very limited debugging capabilities.
  • Learn how registers are the key to microcontroller operation, as opposed to the Arduino ecosystem which prefers obfuscation of these details underneath abstraction layers.
Python library and Graphical utility
The graphical window featured in the cover animation allows exploring the functions of each pin of the hardware live, and also
viewing the corresponding register manipulations executed for each change. This knowledge can then be applied while writing C programs.
  • Android App
    Jithin08/29/2020 at 23:14 0 comments
    KuttyPy hardware can be connected to an android phone via a USB OTG cable.
    The app has basic IO capabilities implemented, and can also log data from 2 sensors as of now
    - MPU6050 - a 6 DOF intertial measurement unit
    - BMP280 - Pressure and temperature sensor
    Around 8 more common I2C sensors will soon be ported
    The source code link is on the homepage, and is begging for contributors. I am very new to android coding, and it is rather painful.
    The app currently supports only ATMEGA32 (version code 99), but can easily be extrapolated to include 238p(Arduino Uno/Nano). No modifications will be required for the I2C sensor loggers since the registers are the same on both processors.
  • Monitor I2C Sensors
    Jithin08/29/2020 at 23:08 0 comments
    Screenshot
    Procedure for using I2C sensors
    • Scan for Sensors
    • Click to monitor via analog gauge
    • List of I2C sensors supported thus far (Minimal data logging. Configuration options via the graphical utility might be incomplete)
      • MPU6050 3 Axis Accelerometer, 3 axis Angular velocity (Gyro)
      • MPU9250 9-DOF sensor
      • MS5611 : 24 bit pressure and temperature sensor. Can resolve 15cm height variations
      • TSL2561 Luminosity measurements
      • BMP280 Pressure and Temperature sensor
      • MCP4725 Single channel DAC
      • PCA9685 PWM controller
      • MLX90614 Passive IR
    results from a Malus Law experiment carried out using a TSL2561 Luminosity sensor, a laser diode, two pieces of polarizers ripped out of an LCD screen, and a hollow shaft stepper motor
    https://kuttypy.readthedocs.io/en/latest/images/malus.png
    The analyzer was rotated step by step, and light intensity was recorded using the light sensor. It confirms maximum transmission when both polarizer and analyzer are parallel, and minimum when orthogonal. It does not go to exactly zero because ambient light was not fully blocked by leveraging a dark room. However, curve fitting showed that the shape was sinusoidal (cos^(theta))
  • R2R DAC based sine wave generator
    Jithin08/29/2020 at 23:05 0 comments
    A simple resistor ladder Digital to Analog Convertor(DAC) was connected to PORTB.
    Then, a C code was written to vary the output in a sinusoidal pattern by writing
    a periodic sequence of values to PORTB
    KuttyPy with R2R DAC Connected to ExpEYES17 oscilloscope
    Scipy based sine fitting reveals the frequency to be 1958.7Hz
    Since calculation of sine values is resource intensive, a set of 128 values between 0 and 255 were generated beforehand and saved in the form of a table into the C code. This task is very easy with Python.
    Create the sine table with Python
    • Create an x axis from 0 to 2*pi
    • Calculate sine of each point (Output between -1 and 1)
    • Scale these values (-1 to 1) to 0-255
    • round off to integers and print
    Python Code
    code to generate table
    import numpy as np
    x = np.linspace(0,np.pi*2,128) #128 points between 0 and 2*pi
    y = 255*(np.sin(x) + 1)/2.
    print([int(a) for a in y])
    Output
    [127, 133, 140, 146, 152, 158, 164, 170, 176, 182, 188, 193, 198, 203, 208, 213, 218, 222,
    226, 230, 234, 237, 240, 243, 245, 247, 249, 251, 252, 253, 254, 254, 254, 254, 254, 253, 252, 250, 248, 246, 244, 241, 238, 235, 232, 228, 224, 220, 215, 211, 206, 201, 196, 190, 185, 179, 173, 167, 161, 155, 149, 143, 136, 130, 124, 118, 111, 105, 99, 93, 87, 81, 75,
    69, 64, 58, 53, 48, 43, 39, 34, 30, 26, 22, 19, 16, 13, 10, 8, 6, 4, 2, 1, 0, 0, 0, 0, 0,
    1, 2, 3, 5, 7, 9, 11, 14, 17, 20, 24, 28, 32, 36, 41, 46, 51, 56, 61, 66, 72, 78, 84, 90,
    96, 102, 108, 114, 121, 127]
    The final C code for sine waves
    This iterates repeatedly through our sine table , and the output can be connected to any oscilloscope for viewing
    #include <avr/io.h>
    // The table we made earlier using Python
    uint16_t table[] = {127,130,133,136,140,143,146,149,152,155,158,161,164,167,170,173,176,179,182,185,188,190,193,196,198,201,203,206,208,211,213,215,218,220,222,224,226,228,230,232,234,235,237,238,240,241,243,244,245,246,247,248,249,250,251,252,252,253,253,254,254,254,254,254,254,254,254,254,254,253,253,252,252,251,250,249,248,247,246,245,244,243,241,240,238,237,235,234,232,230,228,226,224,222,220,218,215,213,211,208,206,203,201,198,196,193,190,188,185,182,179,176,173,170,167,164,161,158,155,152,149,146,143,140,136,133,130,127,124,121,118,114,111,108,105,102,99,96,93,90,87,84,81,78,75,72,69,66,64,61,58,56,53,51,48,46,43,41,39,36,34,32,30,28,26,24,22,20,19,17,16,14,13,11,10,9,8,7,6,5,4,3,2,2,1,1,0,0,0,0,0,0,0,0,0,0,1,1,2,2,3,4,5,6,7,8,9,10,11,13,14,16,17,19,20,22,24,26,28,30,32,34,36,39,41,43,46,48,51,53,56,58,61,64,66,69,72,75,78,81,84,87,90,93,96,99,102,105,108,111,114,118,121,124,127};
    int main (void)  {  uint16_t value=0,position = 0;  DDRB = 255;		// Data Direction Register for port B
      for(;;)    {    value = table[position++];    if(position==255){position=0;}    /* WRITE VALUE TO DAC PORTB which should have a R2R DAC ladder*/    PORTB=value;  }
    return 0;
    • Save this code to example.c
    • Open it using the kuttyPy software
    • Compile and upload!
  • Upgrade an Arduino Uno to KuttyPy
    Jithin08/29/2020 at 22:46 0 comments
    Replace the arduino Uno bootloader with the kuttypy bootloader compiled from source at https://github.com/csparkresearch/KuttyPy-GUI/tree/master/docs/firmware
    In the Python app , run the Graphical interface for Arduino Uno
    python3 KuttyPyUno
    You're looking at an arduino uno running the kuttyPy bootloader, and the Python App reading values from an MPU6050 and showing them on nice looking Guages.
    More at the project page : https://csparkresearch.in/kuttypy#Plug%20and%20Play%20%20I2C%20sensors
    You can simply plug and play a range of I2C sensors, and also add support for more by modifying the Python Library. This is probably the most affordable sensor testing/logging jig out there
    https://kuttypy.readthedocs.io/en/latest/images/kpy_uno.mp4
View all 4 project logs
