The application code written in Forth was completed and the circuit was also completed except for the power supply. It is a dead bug style. But this is a fail the copper pipes sound is not loud enough. It can't be used for a doorbell.
The servo-motor are as noisy as the pipes. Too bad, no more money and time on this project.
Jacques
