First Experiments and Initial calibration
A project log for A DIY Imaging Fluorometer
Is it possible to build a precise Fluorescence Imaging Device at home?
maykeMayke 10/20/2021 at 07:560 Comments
I have been working on the following during the last week:
I wanted to have 500 umoles of light under the chamber, and I also wanted to make sure that it's got the shape (or wavelengths) I want, which I use the spectrometer for. The spectrum is more or less 60% Red, 25% Blue and 15% White. That should please the most demanding plants :)
You can see that I have bundled up together the PAR and the fibre with the cosine corrector using a lab stand with a clamp.
I use the spectrometer to adjust the spectra to the ratios I want.
You can see that I had to migrate from my garage to my home office due to weather conditions (is fall in Europe).
It has taken quite a bit of space though!
Want to see some results?
Above, a nice fluorescence sequence with an initial pulse, followed by 500 umoles and 2-minutes interval pulses.
Finally, a nice picture of cactus sunbathing within the chamber!
Back to work fellas...
