B2 Sample finished - Project Canceled
A project log for Xtruder - A Desktop Filament Extruder
The machine uses an extrusion screw to make filament, yarn and small beams out of plastic pellets and flakes
devlabnrwDevLab.nrw 12/12/2020 at 16:010 Comments
Okay guys, the project will be canceled. Even with the 30mm Screw the results have not been satisfying. The extruded volume was too low and I had a lot of problems with molten pellets stucked and baked on the screw. So I don't want to invest no more effort. Instead I will go on with another project and a 'real' extrusion screw. So stay tuned
