First build report
A project log for Watts Intelliflow timer
Timer based dummy load for washing machine valve
nick-sayerNick Sayer 09/18/2020 at 21:110 Comments
At first blush, the first iteration of the board - with just under 5 watts of dissipation does make an Intelliflow turn on. You have to give it time to turn off, though. Even unplugging the 5 volt wall wart doesn't make the power turn off right away. I believe this is because newer Intelliflows have a 15 minute timeout before they turn off.
~5 watts of dissipation, however, makes for a great deal of heat (and, of course, wasted energy). I am going to try to remove some of the resistors to see if the unit remains reliable without getting so hot.
EDIT: Wow, it turns out two watts is enough. Who knew the Intelliflow was so sensitive? Well, now it looks like even 5 watts isn't reliable. Going to have to do more work.
