Should be expected, when probing bed, z axis moves up and down quickly which caused binding.
If you were able to only print in vase mode on a perfectly flat surface, you can get away with no binding issues. But to allow proper bed probing and z motion (z-hop, etc.), a second belt was added to support the opposite side of the bed.
Parts:
Spool holder with bearings
- 608Z bearings
- 8mm aluminum axle
- M5 preload screw
Z-axis is stiff when attempting to rotate in the y direction.
Also very stiff when pushed in the Z direction on the supported side (held by the belt and stepper). However, the non-supported side does have flex. Its essentially acting as a cantilever bed as the carriage isn't fully constraining that end.
With about 10lb of force applied, Z on unsupported side will move up and down about 0.9mm.
On the plus side the linear rail on the unsupported side is not binding yet. Normally you want belts or screws driving both carriages to avoid binding (https://reprap.org/forum/read.php?397,756640, https://drmrehorst.blogspot.com/ has great info, eg two z motors is not ideal).
TODO:
- measure flex with unsupported side carriage removed (to simulate a cantilever bed). Another option might be to put dual carriages on the supported Z linear rail and use triangular support of the bed.
- extend 2020 to meet face of L bracket, see if it provides additional stiffness
- measure max weight Z axis can hold
Z-axis pulley division:
Each full step should move z-axis 0.03999mm (a number that divides into 0.2mm would be better, but it should be close enough).
Can be divided down with microsteps 1/2, 1/4, 1/8, 1/16: 19.996, 9.998, 4.999, 2.4995um
6mm belt on first stage, then wider 10mm belt on second stage for higher load:
Hopefully bed weight will be <4.4kg.
BMG clone extruder
PTFE tube can be trimmed to length and inserted at the bottom, to reduce flex past the gear teeth
Designed to accept 7mm heat break, secure with set screw.
Titanium heat breaks are available.
Board built up.
Has white LEDs and one red LED for heater on. Red connected to heater 24V, but may make more sense to connect it to hotend fan.
Two bearings inside the block on the left.
80T 6mm and 20T 10mm on 5mm shaft.
Stepper motor on right mounted on 36mm standoffs.
