Second Z belt
A project log for Jubilee all metal build
3D printer
thomasThomas 04/25/2021 at 18:110 Comments
Should be expected, when probing bed, z axis moves up and down quickly which caused binding.
If you were able to only print in vase mode on a perfectly flat surface, you can get away with no binding issues. But to allow proper bed probing and z motion (z-hop, etc.), a second belt was added to support the opposite side of the bed.
Parts:
