Here's the serial output:
Conducting sanity check... Firmware received - launching Heap_low: cef0, heap_size: 1ff2110 Mouse timed out Initialising SD card SPIspin Done - waiting Done SPIspin Done - waiting Done cmd_CMD8 response: 1 CMD8_1 response: 0 CMD8_2 response: 0 CMD8_3 response: 1 CMD8_4 response: aa SPIspin Done - waiting Done CMD55 1 CMD41 1 SPIspin Done - waiting Done CMD55 1 CMD41 0 CMD58 0 CMD58_2 c0 SDHC card detectedSwapping byte order of partition entries Start: 8192 PartitionCount: 1 Partition: 0 Start: 8192 Size: 62325760 Read boot sector from first partition FindDrive() returnedC024576) Changed directory Dhrystone Benchmark, Version 2.1 (Language: C) Program compiled without 'register' attribute Execution starts, 25000 runs through Dhrystone Execution ends Final values of the variables used in the benchmark: Int_Glob: 5 should be: 5 Bool_Glob: 1 should be: 1 Ch_1_Glob: A should be: A Ch_2_Glob: B should be: B Arr_1_Glob[8]: 7 should be: 7 Arr_2_Glob[8][7]: 25010 should be: Number_Of_Runs + 10Ptr_Glob-> Ptr_Comp: 35210 should be: (implementation-dependent) Discr: 0 should be: 0 Enum_Comp: 2 should be: 2 Int_Comp: 17 should be: 17 Str_Comp: DHRYSTONE PROGRAM, SOME STRING should be: DHRYSTONE PROGRAM, SOME STRINGNext_Ptr_Glob-> Ptr_Comp: 35210 should be: (implementation-dependent), same as above Discr: 0 should be: 0 Enum_Comp: 1 should be: 1 Int_Comp: 18 should be: 18 Str_Comp: DHRYSTONE PROGRAM, SOME STRING should be: DHRYSTONE PROGRAM, SOME STRINGInt_1_Loc: 5 should be: 5 Int_2_Loc: 13 should be: 13 Int_3_Loc: 7 should be: 7 Enum_Loc: 1 should be: 1 Str_1_Loc: DHRYSTONE PROGRAM, 1'ST STRING should be: DHRYSTONE PROGRAM, 1'ST STRINGStr_2_Loc: DHRYSTONE PROGRAM, 2'ND STRING should be: DHRYSTONE PROGRAM, 2'ND STRING User time: 2920 Microseconds for one run through Dhrystone: 116 Dhrystones per Second: 8561 VAX MIPS rating * 1000 = 4871
32 MB of allocated memory (33,497,360 bytes)
