HIGH PITCH BELL
TO BUILD A HIGH PITCH BELL
TAKEN DIRECTLY FROM ELECTRONIC SNAP CIRCUITS PRO PROJECT # 265 - HIGH PITCH BELL # 266 - STEAMBOAT WHISTLE # 267 - STEAMSHIP When the circuit is built (as shown) ,by pressing down the press switch ... the circuit generates the sound of a high pitch bell. Going further to the other project ... by placing a 0.02uF Capacitor in parallel (directly across) the whistle chip ... this in turn, when the press switch is pressed down of course ... will cause the circuit to generate a sound some what of that of a steamboat. Finally ... Instead of the 0.02 uf capacitor ... place a 0.1 uf parallel (directly across) the whistle chip .. it now sounds somewhat like a a steamship.
  • 1 × 100k resistor
  • 1 × 1k resistor
  • 1 × LED Fiber Optics / Emitters
  • 1 × one 6volt lamp
  • 1 × 8 ohms speaker
View all 7 components
