1Sketchy-Sketch
Never-ever-ever skip this step. Gets you started, puts you in the right mindset and gives you a clearer idea of what you ar trying to build. Play around with the layouts, get a feel of the dimensions and try to visualize a first iteration of what you're building( it rarely ends up looking like the final product)
2Everybody do the CAD
Design the enclosure and get it ready for laser cutting. Do some rendering so you get some feel regarding the size and feel of the device and maybe play a little bit with the colors.
3Design the circuit
The circuit was designed using Eagle.
4Prepare the wires
53D Print the encoder knobs
This step is optional. You may use comercially available encoder knobs in your build
6Laser-cut the enclosure and prepare all the electronic components
For this first iteration of the midi controller i have decided to use 10 arcade buttons ( they have a really nice feel) and 6 rotary encoders( potentiometers are not suited for the given application)
7Assemble everything according to the schematic and bask at the hot wire mess that you have created
8Load the firmware
To do this, you may use the steps provided here: https://www.pjrc.com/teensy/first_use.html
9Configure Midi2LR to your preference and enjoy
PicsArt employs intuitive commands and functionalities for various editing tools. While the specific keyboard shortcuts seen in software like Adobe Lightroom might not be present in PicsArt, it provides a user-friendly interface with icons, menus, and touch-based controls. In PicsArt, you can access https://betterapk.org/ editing features by tapping on icons or using menus directly on the screen, making it easy to navigate and use tools without relying on keyboard shortcuts.
I love the idea, LR has some UNCONVENIENT ways of jumping around. How does LR get the command and respond? Is it like a key-stroke playback? I didn't think there were keystrokes to jump to each tool/slider. R to crop (why not C like PS?) Q to heal (J in PS!) etc.
