the output of my test board
A project log for ProVol-- My 1ppm DAC accuracy Voltage Reference
This project is based on MAX5719A from Maxim. Hopefully, This will the most easily programable voltage reference.
sushisongrensushisongren 09/11/2020 at 02:443 Comments
测试板
skander36 wrote 06/01/2021 at 08:28 point
Thank you very much!
skander36 wrote 05/30/2021 at 20:30 point
Hello ! I like your project. Can you share the schematic and board. I wish to make a voltage source with high resolution (1 or 10 uV), for calibrating my DMM. Thank you !
sushisongren wrote 05/31/2021 at 22:33 point
Hi! I have upload the sheet. Please check! Hopefully it will help you.
