A project log for ProVol-- My 1ppm DAC accuracy Voltage Reference
This project is based on MAX5719A from Maxim. Hopefully, This will the most easily programable voltage reference.
Thank you very much!
Hello ! I like your project. Can you share the schematic and board. I wish to make a voltage source with high resolution (1 or 10 uV), for calibrating my DMM. Thank you !
Hi! I have upload the sheet. Please check! Hopefully it will help you.
Yes, delete it Cancel
