I have assembled the first board (it is not perfect, but I did it with the iron so, hey!). It is still a bit sticky, however, a more problematic problem is that the regulator is regulating too much and I'm not sure why so it's not working yet. I also really need to start thinking about software which I haven't really done yet. Okay that's it, that's the post, hopefully there will be pictures of it working soon, hopefully. (don't mind the not enough solder on the USB connector, I'll fix it later)
