project_code.inoProject code. Very straightforward; the capacitive sensor reads distance, which translates to the volume of two different audio files. The closer you get, clearer the audio (i.e., less of the 'noise' file)ino - 4.61 kB - 09/13/2020 at 21:03 |
project schematic.fzzElectronics schematic, WIP. I had lots of trouble getting the audio loud and clear enough, still not satisfied with it!fzz - 137.18 kB - 09/13/2020 at 20:58 |
schematic.jpgJPG of the project schematic.JPEG Image - 832.27 kB - 09/13/2020 at 20:58 |
stoy_edited_final.docxText of the story that is told by the sculpture.document - 45.74 kB - 09/13/2020 at 20:58 |
3d_sketch.objThe 3d model I made before I started the sculpture. I 'sliced' this into pieced and cut them out of foam for the sculpture's core.obj - 13.84 MB - 09/13/2020 at 20:59 |
packed_2.pdfThe 'slices' of the 3d model, which I created as a reference. I cut these slices out of Foamular, stacked and glued them to create the sculpture's core.Adobe Portable Document Format - 1.30 MB - 09/13/2020 at 21:02 |
Muhsin Mahdi_cropped_rotated.pdfThe original Arabic version of the story. Mahdi collected written versions of the (originally, orally transmitted) 1001 Nights, some versions as old as the 9th century!Adobe Portable Document Format - 4.45 MB - 09/13/2020 at 21:06 |
