Adapter PCB for supercapacitor
A project log for Supercapacitor Rapid Charger
A 6 Amp supercapacitor charger, and a small tutorial on charging
sciencedude1990sciencedude1990 09/14/2020 at 03:370 Comments
Just for reference, I made a small adapter PCB for the supercapacitor.  This let's you attach wires to the supercapacitor and use the strain relief of the supercapacitor mounting pins.
Then you can place twist on connectors to the wires to prevent accidental shorting.
