Voron Switchwire 3D Printer
Voron Switchwire - DarekNorway Build Log
My Voron Switchwire build log is updated here on HackaDay My Voron 2.4 V2.601 3D Printer build log is updated on Thingiverse: https://www.thingiverse.com/thing:4240260
Voron Switchwire GitHub >>> https://github.com/VoronDesign/Voron-Switchwire
Portable Network Graphics (PNG) - 69.25 kB - 02/16/2023 at 23:10
Preview
VSW_Feed_Slot_Clamp_Top.stl
https://hackaday.io/project/174810-voron-switchwire-3d-printer/log/200085-voron-switchwire-upgrade-feed-slot-clamp
Standard Tesselated Geometry - 1.33 MB - 11/06/2021 at 13:42
Download
VSW_Feed_Slot_Clamp_Bottom_3mm_3mm.stl
Standard Tesselated Geometry - 44.51 kB - 11/06/2021 at 13:42
Download
VSW_Feed_Slot_Clamp_Bottom_4mm_3mm.stl
Standard Tesselated Geometry - 66.21 kB - 11/06/2021 at 13:42
Download
acrilic_enclosure_side_walls_support_v2_x2.stl
Standard Tesselated Geometry - 113.95 kB - 03/14/2021 at 15:55
Download
View all 13 files
  • 1 × Doble-Sided Tape <a href="https://s.click.aliexpress.com/e/_AEXXai"> Double-sided adhesive 0.5mm thick black foam 20mm tape</a>
  • 1 × Raspberry Pi 4 Power Cable <a href="https://s.click.aliexpress.com/e/_AlxlKr">Raspberry pi 4 power switch line type-c interface 5V 3A USB power supply</a>
  • 1 × Dragon Hotend <a href="https://s.click.aliexpress.com/e/_d6lvm4p">TiangleLab Dragon Hotend V2.0 High Flow</a>
  • 100 × Brass Hot Melt Inset Nuts M3 X D5.0 X L4.0 <a href="https://s.click.aliexpress.com/e/_AMGKjt">Brass Hot Melt Inset Nuts Heating Molding Copper Thread Inserts Nut SL-type Double Twill Knurled Injection Brass Nut</a>
  • 1 × BMG Extruder Componnets Kit <a href="https://s.click.aliexpress.com/e/_97A4sd">Trianglelab BMG Direct Drive Basic kit</a>
View all 54 components
View all 41 project logs
Ivan Stepaniuk wrote 01/19/2021 at 14:40 point
Nice! Are you happy with the results in terms of print quality?
