Voron Switchwire GitHub >>> https://github.com/VoronDesign/Voron-Switchwire
Voron Switchwire - DarekNorway Build Log
printer.cfgFirmware - Klipper configcfg - 6.06 kB - 02/05/2021 at 17:25 |
Voron Switchwire - Homing.mp4Voron Switchwire - Homing, G28. X axis - Microswitch Endstop Y axis - Microswitch Endstop Z axis - Inductive Probe Build log: https://hackaday.io/project/174810-voron-switchwire-3d-printer BTT SKR mini E3 V2.0+Raspberry Pi4 8GB +Octoprint + Octopi + KlipperMPEG-4 Video - 30.65 MB - 01/31/2021 at 12:57 |
Standard Tesselated Geometry - 307.70 kB - 01/23/2021 at 21:44 |
Standard Tesselated Geometry - 307.70 kB - 01/20/2021 at 02:22 |
Standard Tesselated Geometry - 75.08 kB - 01/20/2021 at 02:22 |
Voron Switchwire - Y-axis Sensorless Homing - TMC2209, G28.
Y axis - Sensorless (TMC2209 Stepper Motor Driver Virtual Endstop)
BTT SKR mini E3 V2.0 + Raspberry Pi4 8GB + Octoprint + Octopi + Klipper
printer.cfg
[stepper_y]
step_pin: PB10
dir_pin: !PB2
enable_pin: !PB11
step_distance: 0.0125
###Sensorless Homing
#endstop_pin: ^PC1
endstop_pin: tmc2209_stepper_y:virtual_endstop
homing_retract_dist: 0
###End Sensorless Homing
position_endstop: 227
position_min: 0
position_max: 227
homing_speed: 70
homing_positive_dir: true
[tmc2209 stepper_y]
uart_pin: PC11
tx_pin: PC10
uart_address: 2
microsteps: 16
run_current: 0.5
hold_current: 0.3
interpolate: True
stealthchop_threshold: 250
diag_pin: ^PC1
driver_SGTHRS: 170
Voron Switchwire - PLA Spiral Vase Mode Printing
Components: https://hackaday.io/project/174810/components
https://hackaday.io/project/174810-voron-switchwire-3d-printer#menu-components
JST Connector Plug 2pin Female, Male and Crimps
TriangleLAB - Prusa MK52 Heated Bed - 24V
My Voron Switchwire BOM: https://hackaday.io/project/174810/components
Nice! Are you happy with the results in terms of print quality?
