22.01.2021 - Voron Switchwire - Electronics Mounting
A project log for Voron Switchwire 3D Printer
Voron Switchwire - DarekNorway Build Log
dareknorwayDarekNorway 01/22/2021 at 17:110 Comments
Voron Switchwire - Electronics Compartment
(with additional 12VDC PSU for Fans, Leds...)
<Gdstime Dual Ball 5000RPM 60mm DC 12V Cooling Fan 2Pin Brushless 60x60x20MM
Gdstime, Dual Ball 5000RPM 60mm DC 12V Cooling Fan 2Pin Brushless 60x60x20MM
Raspberry Pi 4B 8GB
Raspberry Pi 4B 8GB
Rocker Switch, IEC Power Supply Inlet and Fuse
IEC inlet module AC power socket with fuse EMI filter 6A 115V/250V 50HZ/60HZ
Main Power Supply Unit SMUN LRS 350W 24VDC
Additional Power Supply Unit 60W 12VDC (for Fans, Leds...)
Additional Power Supply Unit JCPOWER  60W 12VDC (for Fans, Leds...)
PSU JCPOWER 20W 5VDC (for Raspberry Pi)
PSU JCPOWER 20W 5VDC (for Raspberry Pi)BIGTREETECH SKR Mini E3 V2 Control Board 32Bit with TMC2209 Drivers
