Portable Network Graphics (PNG) - 69.25 kB - 02/16/2023 at 23:10 |
VSW_Feed_Slot_Clamp_Top.stlhttps://hackaday.io/project/174810-voron-switchwire-3d-printer/log/200085-voron-switchwire-upgrade-feed-slot-clampStandard Tesselated Geometry - 1.33 MB - 11/06/2021 at 13:42 |
VSW_Feed_Slot_Clamp_Bottom_3mm_3mm.stlhttps://hackaday.io/project/174810-voron-switchwire-3d-printer/log/200085-voron-switchwire-upgrade-feed-slot-clampStandard Tesselated Geometry - 44.51 kB - 11/06/2021 at 13:42 |
VSW_Feed_Slot_Clamp_Bottom_4mm_3mm.stlhttps://hackaday.io/project/174810-voron-switchwire-3d-printer/log/200085-voron-switchwire-upgrade-feed-slot-clampStandard Tesselated Geometry - 66.21 kB - 11/06/2021 at 13:42 |
Standard Tesselated Geometry - 113.95 kB - 03/14/2021 at 15:55 |
led_strip.stl250mm Bracket for 170mm LED stripStandard Tesselated Geometry - 31.14 kB - 03/06/2021 at 12:27 |
printer.cfgFirmware - Klipper configcfg - 6.06 kB - 02/05/2021 at 17:25 |
Voron Switchwire - Homing.mp4Voron Switchwire - Homing, G28.X axis - Microswitch Endstop Y axis - Microswitch Endstop Z axis - Inductive Probe Build log: https://hackaday.io/project/174810-voron-switchwire-3d-printer BTT SKR mini E3 V2.0+Raspberry Pi4 8GB +Octoprint + Octopi + Klipper MPEG-4 Video - 30.65 MB - 01/31/2021 at 12:57 |
Standard Tesselated Geometry - 307.70 kB - 01/23/2021 at 21:44 |
Standard Tesselated Geometry - 307.70 kB - 01/20/2021 at 02:22 |
Standard Tesselated Geometry - 75.08 kB - 01/20/2021 at 02:22 |
stl[1] - 89.33 kB - 10/11/2020 at 17:09 |
Rubber_Compressor_Foot_Washer_15x5.4x3mm.stlhttps://hackaday.io/project/174810-voron-switchwire-3d-printer/log/184891-11102020-voron-switchwire-vibration-managementStandard Tesselated Geometry - 9.46 kB - 10/11/2020 at 16:25 |
