11.10.2020 - Voron Switchwire Vibration Management
A project log for Voron Switchwire 3D Printer
Voron Switchwire - DarekNorway Build Log
dareknorwayDarekNorway 10/11/2020 at 16:090 Comments
4x Rubber Compressor Foot
4x Spring T-nut series 30xM5
4x BHCS M5x16
Links to suppliers you can find in components list section >>> https://hackaday.io/project/174810-voron-switchwire-3d-printer#menu-components
4x 3D ABS printed Washer 15x5.4x3mm. STL file >>> https://cdn.hackaday.io/files/1748107479071040/Rubber_Compressor_Foot_Washer_15x5.4x3mm.stl
