15.01.2021- Voron Switchwire Magnetic Heat Bed MK52
A project log for Voron Switchwire 3D Printer
Voron Switchwire - DarekNorway Build Log
dareknorwayDarekNorway 01/15/2021 at 14:460 Comments
Voron Switchwire - Double sided Textured PEI Spring Steel Sheet for Prusa MK52
Voron Switchwire - Double sided Textured PEI Spring Steel Sheet for Prusa MK52 - TriangleLab
Voron Switchwire - TriangleLAB 24V PRUSA i3 MK3 MK3S up to 130°C continuous Heated Bed spring steel plate
FYSTEC - 6x6x3mm Aluminum Spacer
Voron Switchwire - FYSTEC - 6x6x3mm Aluminum Spacers
TriangleLAB - Prusa MK52 Heated Bed - 24V
My Voron Switchwire BOM: https://hackaday.io/project/174810/components
