24.01.2021 - Voron Switchwire - Power Supply Wiring and Crimping
A project log for Voron Switchwire 3D Printer
Voron Switchwire - DarekNorway Build Log
dareknorwayDarekNorway 01/24/2021 at 11:290 Comments
Voron Switchwire - Power Supply Wiring 230VAC, 24VDC, 12VDC, 5VDC
OV DC (-)Pin of 24V PSU and 0V DC(-)Pi of 12V tied together to control both 24V and 12V devices using SKR mini E3 Board v2.0 connected to 24VDC PSU
230VAC splicing connectors - Wago 221-615, 5x 0.5...6mm2 (20...10AWG)
24V DC (+Pin) splicing connector - Wago 221-415, 5x 0.2...4mm2 (24...12AWG)
3A Raspberry Pi 4 Power Cable USB To Type-C Charging Wire ON/OFF Switch For Raspberri RPI 4
https://hackaday.io/project/174810-voron-switchwire-3d-printer#menu-components
