RGB HexMatrix | IOT Clock 2.0
Back to overview
PCB Version Of The Previous HexMatrix Clock.
Minocc wrote 12/10/2020 at 01:42 point
If you add the WifiManager library, you can replace all the wifi connection code with two lines,
 WiFiManager wifiManager;
wifiManager.autoConnect("AutoConnectAP");
and it will make an access point when it doesn't detect a known network.  Very helpful if you plan, like I do, to give these as gifts!
