Bootloader Wake Time Improvements
A project log for ESP-NOW Weather Station
An ESP32 based weather station investigating ESP32's Deep Sleep and ESP-NOW
kevin-kesslerKevin Kessler 09/19/2020 at 02:503 Comments
Both the anemometer and the rain gauge use reed switches to send pulses to the microcontroller indicate the value of the sensor.  The anemometer closes the switch on each rotation, so that a 2.4 km/h breeze will cause the switch to close once per second. The tip bucket rain gauge will cycle the reed switch on every .2794mm of rain. My initial approach was to connect each of these to a GPIO that would wake the ESP32, which would then update the appropriate counter and go back to sleep.
The ESP32 wakes from deep sleep is level triggered instead of edge triggered, and if you set the uC to wake on a low input, for example, and the input is still low when you the ESP is put to sleep, it will immediately wake. The result of this is in order to get an accurate measurement of counts you need to emulate an edge triggered interrupt.  To do this, you need to set the wakeup signal to a low on the GPIO, programmatically note the low event when it occurs, then set the the wakeup signal to a high on the GPIO. When the high wakes the ESP32, the count can be recorded. The switch is hardware debounced with a low pass filter, and it would have been a good idea to put some time based software debouncing in, but it turns out that the ESP32 is so slow to wake, it isn't necessary.
On doing some initial testing, I found that it takes the ESP32 around 192ms to wake from deep sleep. Having to wake twice on every count would limit the ESP32's anemometer reading to about 6km/h. Assuming 100km/h as the max wind speed I need to measure (pretty strong wind which might tear the station off its poll), I would require the ability to handle about 84 wake events per second, so this is not close to meeting the requirement. The fastest rainfall recorded in the US was 17.5mm in one minute, which generate a wake event about twice a second, which would be doable (although, under that much rain, something else would probably break).  I set about trying to decrease the wake time.
To measure the baseline bootloader time, I wrote a program which toggled a GPIO, set a wake up timer for 1uS, and went to sleep:
#include <Arduino.h>
void setup() {
  pinMode(GPIO_NUM_12,OUTPUT);
  digitalWrite(GPIO_NUM_12,1);
  esp_sleep_enable_timer_wakeup(1);
  digitalWrite(GPIO_NUM_12,0);
  esp_deep_sleep_start();
void loop() {
  // put your main code here, to run repeatedly:
Then I could monitor the GPIO with my oscilloscope to determine the speed at which the ESP32 can cycle through deep sleep.
Since 18uS pulses are not very visible in the image with 50mS per division, I turned on measurements, and you can see the period between program runs is 191 mS (lower left).
This is a list of things I've done to try to speed things up:
I'm using PlatformIO as my IDE, and the first 2 settings are made with the platformio.ini options
board_build.flash_mode = qio
board_build.f_flash = 80000000L
The rebuild of the bootloader consisted loading up the Espressif IDF native SDK, and running menuconfig. Under PlatformIO this just consists of creating an ESP32 project with the espidf framework, so the hard work is done for you. You then can run:
pio run -t menuconfig
In order to get all the bootloader configuration options, though, you need to be using the newest espressif32 platform, so the platform directive in platformio should read:
platform = https://github.com/platformio/platform-espressif32.git
in order to get the yet to be released 4.1.0 version.
In menuconfig, under "Bootloader Config", I enabled "Skip Image Validation when waking from Deep Sleep" (which I think made the most difference), set the compiler optimization to -O2 for speed, and turned off all logging. Under the "Serial Flasher Config", I set the mode to QIO and speed to 80MHz, and under "Component Config" I set log output to None. Build the project and you end up with a bootloader.bin in the project_folder/.pio/build/esp32dev directory.
To get this bootloader into an Arduino Framework project, you first must understand how Platformio (and probably the Arduino IDE as well) find a bootloader to load into your ESP32. Normally a group of prebuilt bootloaders are found under $HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/bin, and they are named with the convention bootloader_mode_flashspeed.bin, so with the configuration of mode=qio and flash speed=80MHz, the targeted bootloader is bootloader_qio_80m.bin.
Now you could copy the newly compiled bootloader.bin to the folder under the home directory, but these bootloaders are shared by all PlatformIO projects, and I didn't want to screw up some other project. You can create a private copy of the packages directory with the following directive in platformio.ini:
[platformio]
packages_dir=./packages_dir
This way you can copy the new bootloader.bin to project_dir/ packages_dir/framework-arduinoespressif32/tools/sdk/bin/bootloader_qio_80m.bin, and the next time the ESP32 is flashed, it will get the new bootloader.
 The final test I ran was to rewrite my Arduino test code into native ESP IDF code:
#include <stdio.h>
#include "driver/gpio.h"
#include "esp_sleep.h"
#include "sdkconfig.h"
void app_main() {
    gpio_reset_pin(GPIO_NUM_12);
    gpio_set_direction(GPIO_NUM_12,GPIO_MODE_OUTPUT);
    gpio_set_level(GPIO_NUM_12,1);
    gpio_set_level(GPIO_NUM_12,0);
This code ran with a period of 28mS, which means that there is still something inside the Arduino code which is eating up a lot of time. The actual time between the GPIO going high and going low in the Arudino Code was 18uS and the IDF code was 7uS, so the time is being lost somewhere less obvious. Even 28mS is not fast enough for the requirements of the anemometer, so the anemometer counter will have to be accomplished with some sort of event counting IC.
Alejandro wrote 10/08/2023 at 12:31 point
Hi,
I'm trying to reduce boot times on my ESP32 devkit module with the Arduino framework using Platformio IDE.
I managed to do it with the ESP-IDF framework.
About the part of copying the compiled bootloader.bin:
Inside $HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/ are multiple esp32 folders (this is due to new esp32 devices coming out since 2020), my chip is the original esp32, but in $HOME/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32/bin there are only .elf files, not .bin files, e.g. bootloader_qio_80m.elf, bootloader_dio_40m.elf, etc.
Copying the generated .elf file project_folder/.pio/build/esp32dev into project_dir/ packages_dir/framework-arduinoespressif32/tools/sdk/esp32/bin/ made the trick ! Using the .bin file wasn't working.
About boot time reduction, without any optimizations, a simple gpio turn on sketch was taking 180ms to boot. After modifying platformio.ini with this:
board_build.flash_mode = qio ;Boot time went from 180ms to 168ms
board_build.f_flash = 80000000L ;Boot time went from 168ms to 156ms
And with the custom bootloader I measured 74ms
I wish there was an easier, more straight-forward way to using custom bootloaders.
Kevin Kessler wrote 07/31/2021 at 03:53 point
You really don't configure PlatformIO for the bootloader specifications; it is done in the platform.ini on a per project basis.  If you don't specify anything, I think it defaults to qio and 40MHz. There isn't a way in your code to query it, because the bootloader is a completely separate loaded piece of code. In fact, you can probably see which bootloader is uploaded by doing your upload through the command line. It would be something like pio run target upload -v (I'm doing this from memory so you could google it to be sure, make sure you use the verbose flag). When you do it right, it will show the esptool.py command that it uses to upload the code, and in there you will see which bootloader it is uploading, and the name will indicate the mode and speed.
MacGyver wrote 07/31/2021 at 03:11 point
What's a way to tell if I've got PlatformIO configured correctly for a given flash mode and speed on the ESP32? Should it show the speed/mode on the serial console during its boot, or are there esp_* functions available to confirm it?
