Convection Fan
A project log for T-962A Reflow Oven Modifications
Modifications to a T-962A reflow oven which turn this cheap oven to a surprisingly effective piece of hardware.
lanceLance 08/31/2021 at 23:410 Comments
Introduction
One of the biggest issues people report with these ovens is that some parts of their PCBs don't get hot enough to reflow the solder while other parts get so hot they components start to get burnt.  In Jerry Walker's video series he adds and small convection fan and concludes this is one of the most beneficial modifications to prevent this issue.
This was, by far, the most difficult modification.  It requires adding a motor, a switch, and the fan blade.  However, the ideal position for the fan blade is in the center of the heating chamber and there is a thermocouple located there.  I chose to relocate both thermocouples to the side of the chamber.  This also freed up room above the heating elements to allow the fan blade to be installed between the heating elements and the top of the chamber.
Relocating the Thermocouples
The thermocouples were originally located at the top of the chamber.
Original Location of the Thermocouples
The original location of the thermocouples (blue circles).
To mount the thermocouples to the side of the chamber, I used some lamp hardware.  It is cheap and available at most home centers.  The hardware is metal so it will stand up to the heat, the nipples are hollow which allows running the thermocouples through them, and there is nuts and washers for mounting everything.
Lamp Hardware
The lamp hardware used to remount the thermocouples. This hardware is cheap and readily available at home centers.
I drilled some holes big enough for the nipples through the side of the chamber.  A washer and nut on each side of the chamber wall held them in place.  Then it was just a matter of running the thermocouples through and applying some heat-resistant silicone to seal them.
Relocated Thermocouples
The thermocouples related to the side of the heating chamber and mounted with lamp hardware.
Motor
I chose an N20 hobby motor.  It works, but the thing is very noisy.  If I was to do this again, I'd definitely look for a quieter motor.  A 12v motor was selected so it could run directly off the power available on the control board.
Some standoffs were used to attach a small plate to the top of the heating chamber.  A square was cut out of the insulation to allow it to be positioned around the stand.  The insulation square that was cut out was then modified to fit between the standoffs and allow the fan driveshaft to pass through.  The motor was mounted above the insulation to prevent it from overheating.
Motor and Switch
The motor for the convection fan is mounted to the top center of the heating chamber. It is mounted above the insulation so it does not get too hot. A separate, external switch was added to allow it to be controlled independently.
An external switch was added to allow independent control of the convection fan.  Heat shielding was used on the wires from the motor.  Disconnects were added between the motor and switch to allow service of the oven or motor replacement.
Fan Blades
I made two different sizes of fan blades.  The first was as close as I could match to the one Jerry Walker created.  The second size was much larger.  After testing, the larger fan blade led to a large discrepancy between the readings of the thermocouples and what I was reading on a PCB placed in the oven.  In the end, I went with the version Jerry Walker used.
Fan Blades
Two different sizes of fan blades were tested. The bottom one was determined to give the best results.
