Python Supported (Again)
A project log for TallyPi
Build network controlled tally lights for live cameras, intended for control by OBS but extensible enough to use for whatever you like.
deckeregoDeckerEgo 06/28/2021 at 02:440 Comments
Now that Python support for MacOS has returned in OBS 27, Python is now re-established as the default script type for TallyPi. The Lua script will continue to be supported - so both are viable options.
Bear in mind the Lua script actually just turns around and calls curl... so it's not a portable option. The Python script is self-contained and uses the default Python HTTP libraries.
