Rebalance Progress
A project log for Raspberry Pi Ceph Cluster
A Raspberry Pi Ceph Cluster using 2TB USB drives.
robert-rouquetteRobert Rouquette 10/13/2020 at 21:010 Comments
The rebalance is still progressing.  It's particularly slower because I also changed the failure domain on my cephfs EC pool from OSD to HOST which increased the number of PGs that needed to be remapped.  Aside from that, the rate of progression appears fairly typical.  The two gaps in the plot are power outages caused by Hurricane Delta.
