A project log for GPRino
Ground Penetrating Radar using Arduino
mirel-paunMirel Paun 10/08/2020 at 16:030 Comments
System tested and works fine.
Antenna coupling is quite high. Would be nice placing the antennas at a bigger distance from each other, or using more directive antennas in order to reduce unwanted coupling.
