Teensy 4.1 CNC Controller
Teensy 4.1 based 5 Axis, Ethernet CNC controller running grblHAL.
Public Chat
Starting from
$27.99
PhilBa has 364 orders / 14 reviews
Ships from United States of America
Teensy 4.1 Breakout Board for grblHAL Motion Controller SW. Supports up to 5 Axes, VFD Spindles (0-10V, PWM, Relay), Dust Extraction Relay ganged to Spindle, Independent control of Dust Extractor (for later clean up), I2C and Serial connections, Can directly drive 7 relays including Spindle, Dust Extractor, Flood coolant, mist coolant and 3 auxiliary relays. Interface is via USB or Ethernet. Screw terminals for reliable connections.
Designed for grblHAL, a 32-bit version of the classic Grbl motion controller. grblHAL runs on a number of 32-bit microcontrollers including iMXRT1062 (Teensy 4.x), STM32 (blue and black pill), ESP32, SAM (Due and MKRZERO) and TI 432. It supports high stepping rates. I spec my board for 160 KHz but bare grblHAL can produce up to 400KHz. Highly modular, it is easy to configure. It is definitely not your father's Grbl!
This is currently running in a number of CNC machines. The photos show an entry level CNC machine with a 300x300mm work envelope
T41U5XBB v207.pdf
User manual including assembly instructions and BOM.
Adobe Portable Document Format - 7.62 MB - 10/05/2020 at 05:11
Preview
Download
The Big One wrote 04/09/2021 at 20:05 point
This looks awesome!  I'm currently picking out a CNC frame (leaning toward the Workbee / Queen bee currently, but not sure).  If I can get it working with the basic 8 bit GRBL controller I'll look to upgrade to this one down the road.
Currently on Tindie there is only one left.  Are you planning on re-stocking?  (No rush of course... this is likely months out for me).
The Big One wrote 04/11/2021 at 16:32 point
I ended up jumping on this after all, and got the last board.  Now I just need my CNC components to arrive...
3D2Code wrote 11/18/2020 at 15:30 point
I looked at the grbl-HAL code on GitHub and looks like it supports G5 (cubic bezier splines) in 2 axes. Do you know whether there is a plan to expand this to all 5 axes?
phil-barrett wrote 11/20/2020 at 07:08 point
Sorry for responding so late.  I don't know the answer. You could ask Terje (the grblHAL developer) on the grblHAL github repository in the issues section - https://github.com/terjeio/grblHAL
3D2Code wrote 11/20/2020 at 14:10 point
Will do.
phil-barrett wrote 11/18/2020 at 08:34 point
Drew, those are real  TB6600 drivers. I bought them a few years ago before the plague of fake TB6600s arose like Covid.  I did a tear down on one of the current "TB6600" drivers - not a real TB6600 chip in it.  https://www.grbl.org/single-post/tb6600-fake-or-not-but-who-cares  I am hard pressed to find a driver built around a real Toshiba TB6600.
drew wrote 11/18/2020 at 08:11 point
Just wondering what driver boards you're using in the above system.
phil-barrett wrote 11/17/2020 at 17:52 point
I am currently sold out of boards but I have a new shipment waiting for carrier pickup in Shenzhen. Should be here by the end of the week.
phil-barrett wrote 11/21/2020 at 23:37 point
Well, FedEx is a bit slower than I thought. They are now saying Tuesday11/24 though they some times under promise/over deliver. So, you might want to check the Tindie store on Monday.
phil-barrett wrote 11/16/2020 at 21:56 point
Hello, a quick update. I am putting the finishing touches on a "Pro" version of the board.  It includes FRAM for logging machine time, Pluggable Screw Terminals, USB Host support, high speed quad encoder support, spindle sync input and daughter card mounts for I2C and Serial IO.  Updates as I start testing the first boards.
phil-barrett wrote 11/14/2020 at 21:23 point
Thanks.  It's based on a CBeam router from open builds.  Here are some detail https://www.grbl.org/cbeam-machine
To be honest, wouldn't recommend the mechanicals. It's OK but I don't like the moving bed on a single CBeam rail.   Better to get a small WorkBee.  Happy to answer any other questions.
jason wrote 11/14/2020 at 20:50 point
i know the project is about the controller, but i love the look of your cnc router.. any details?
