FreeCAD Foray: "Refrigerator Rover" Base Design.
The FreeCAD design process I used to design the Base for the Refrigerator Rover.
A video of how I designed the base component of my Refrigerator Rover using FreeCAD.
The video is here: https://youtu.be/Rw_KrmdXx4E.
Greg Zumwalt wrote 10/09/2020 at 21:36 point
Hi Dan!
Thank you very much, I'm hopefully it helps!
FreeCAD utilizes a "one sketch creates one solid" approach to modeling, and as I tried to illustrate in the video, creating the "base" component consists of a sketch for each "solid to be", which is then "padded" (or extruded) into a the various solids that make up the base body.
I'm still learning, but for me, it is a very viable alternative.
Thanks again!
Greg
Dan Maloney wrote 10/09/2020 at 20:14 point
Helpful video, it makes FreeCAD look a lot more approachable than I thought. I have to give it a whirl. Thanks!
