The switch issue
A project log for WTF - Walking Turtle Finder v1
A device which helps you to find your turtle walking in the garden.
Danya0x07Danya0x07 10/10/2020 at 20:410 Comments
The first prototype uses the FS1000A radio modules. That is the cheapest but not a reliable option because these modules are very sensitive to power voltage stability, so there was a trouble with the switch: the device worked bad and it was very difficult to determine, why. But the issue was in the switch - it's replacement to a simple breadboard wires fixed the bug.
The switch had to be replaced with breadboard wires.
