The first prototype uses the FS1000A radio modules. That is the cheapest but not a reliable option because these modules are very sensitive to power voltage stability, so there was a trouble with the switch: the device worked bad and it was very difficult to determine, why. But the issue was in the switch - it's replacement to a simple breadboard wires fixed the bug.
