Extracting the ROM board and attempt dump!
A project log for Dissecting a hand-held NOAC console
This is an attempt to understand how these little things work, and what we can do on it.
nyh-workshopNYH-workshop 11/14/2020 at 15:030 Comments
After getting the ChipQuik and try to manually remove the thing without overheating it (I hope so), I got the thing out finally!
And with that SO-44 to DIP adapter I have, this will be handy in dumping the ROM without resoldering the wires to the ROM board again.
However, I have to file off the edges a bit just for the board to fit into the adapter:
This is how it looks like after it is fitted into the adapter:
And after connecting it again to the board with MCP23017 and a Raspberry Pi I tried reading the first few bytes just to see a 0xFFFF or 0xFF00 as the data output. It can't be even right and these values are not even consistent! So after a few hours of research and digging, I'm suspecting that there's an RST pin which I missed out:
There it is. After soldering it to +3.3V and reattempted the read, it finally give a meaningful output (or at least it doesn't jump around or keep showing 0xFFFF for multiple reads on the same address).
Next is how am I gonna dump the rest of the whole thing? This is the question and I'm writing up a Python script inside now.
