Opcodes has its bits swapped??
04/11/2024 at 03:51 • 0 commentsAfter from the previous log, I took a look in the EmuVT's debugger and noticed that there are many jumps to a nearby locations and "strange" opcodes that don't make any sense:
Hmm... looks like some of the stores especially at the $412D could make sense, since these stuff often use the registers around that address. And the jumps too. Look at the end with the "F5FE" - looks like a jump to the main startup code?
Wait... I recalled about chatting about those VT-02 OneBus systems at NesDev Discord, and also these NesDev article: https://www.nesdev.org/wiki/NES_2.0_Mapper_256, and another BGC article: http://bootleg.games/BGC_Forum/index.php?topic=2412.0
Something reminded me that there could be swapped bits somewhere in the opcodes. After checking these instructions on a pen and paper, bits 4 and 5 at the opcodes are actually swapped!
After swapping these bits manually in HxD and pasted this modified code back, it runs on the EmuVT now!
These newer Sup 400-in-1 handhelds are having these strange bit-swaps at the addresses, and this one having a bit-swap at its opcodes before the startup happens!
Another new romdumper - this time it's faster!
04/11/2024 at 03:32 • 0 commentsWhen trying to dump a newer Sup 400-in-1 ROM on my Raspberry Pi based dumper, the thing doesn't load well in the emulator. There are many corruptions in the ROM when viewed through the YY-CHR app. The little dots at the empty area are those corruptions:
Plus, this thing takes a whole day to dump and it's really slow, and I have a better idea to port this whole thing to a Raspberry Pico instead. After figuring out the newer problems such as the MCP23017s couldn't be detected and these corruptions, I had modifications to the circuit:
This time, it dumps really fast and about 35 mins later I get the 16 megabytes ROM dump. You can check this ROM dumper here too if you want a faster alternative!
However, when trying to run it in the EmuVT - it just gives me a black screen and it doesn't work! What gives?
Dissecting the startup!
03/31/2024 at 03:41 • 0 commentsAs mentioned in the previous logs, if you have used this method, you may able to get the dump and run this binary in the EmuVT emulator.
So on about last year, I actually dissected the flow of the program and written it into a piece of paper. This analysis does not include how the game menu works and the test screen - only the startup.Using the EmuVT emulator and putting breakpoints one by one, I managed to see things like:
- Getting the starting address at $7FFFC.
- Initializing registers at $412B and $412C.
- Dumping about 15 values into the $4200.
- It went on jumping back and forth around addresses $60000 and $70000. Most of the TFT startup and the menu, and Aaronix test screen logic are situated at $60000.
- OneBus switching seems to be performed in RAM.
- The TFT initialization seems to follow a pattern. There are multiple loads and stores, and digging the pattern in Google, the model is actually GC9306. Datasheet here.
- The register $4233 possibly controls the 16-bit parallel LCD outputs to be a GPIO or the parallel LCD. When it is set at $84, this might becomes a GPIO - during the TFT initialization it does this. When done the initialization routines, this is set at $04.
- The functions that write the command and data to the TFT uses $4230 and $4231. At $4233 again if it is a write command, $94 is written. If it is a write data, $D4 is written.
- Finally, around the starting point of the game menu, $412C is written $0F to enable the backlight.
These are also verified using the homebrew flash emulator that dumps part of the ROM ($60000-$80000) into the Teensy 4.1.
With the flash emulator, using the stripped ROM, I managed to try adding a while loop at certain places in the ROM (usually 4C xx xx) to 'halt' the program. This is useful when I want to see when the backlight gets switched on. Initially, it is thought that the backlight is switched on at the TFT initialization routines. However, putting the command inside does not work (backlight doesn't lit up), and I had to try adding this 'halt' between the function calls when the menu is running. When one of the locations are being known to switch on the backlight, I focused into it and found out that putting the $0F into the $412C actually does this thing.
I dumped two of these ROMs (one bought in 2020, and another somewhere later) and one of them have swapped bits 1-2 and 9-10 at the data pins! Some of them have very different starting vectors too - one started at $FF00, and one at $FEF5. However, they all use the same mentioned registers and these apps could possibly work on another similar Sup 400-in-1 consoles.
One more issue - where are the registers that controls the external sound speakers?
It is working, but might not be fully functional!
03/23/2024 at 16:54 • 0 commentsAfter looking at the code and checking the Teensy 4.1's processor datasheet, it is known that there are edge interrupts on a row of GPIO pins. It means, if any pins at GPIO6-9 are changed, it triggers an interrupt.
I'm suspecting that the polling of the address lines by Teensy couldn't catch up with the speed of the switching addresses at the NOAC. Having the pin change interrupt makes it easier for the NOAC to catch the instruction that is fed from the Teensy pins.
And... yes, there's the game menu, and it jumped into the test screen when I hold the A + B before the thing starts:
Unfortunately, there are limitations - the Teensy needed to be overclocked to 912MHz to do this successfully, and a heatsink is required. I am now figuring a way to have a fan to blow on the heatsink, and also to write up short pieces of 6502 code to make it run on that NOAC.
And here's the Github page if you are interested in replicating the project.
Partially working, needs more improvements!
03/23/2024 at 15:42 • 0 commentsFrom the previous log... what would happen when a short piece of code is being loaded and run after applying the reset?
And for a short description on how this is done:
- Dump the ROM according to this log - make sure it can run in the emulator!
- On the ROM, using the hex editor such as HxD, cut out the range of address 0x60000-0x80000.
- Still in the hex editor, create an empty new binary file and paste it in. Save it separately!
- In the Teensy's application, the binary file is being received through Ymodem (using this method) from the PC.
- After receiving the file, the app resets the NOAC on the PCB.
- The app rapidly polls for the address changes (A0-A17) and pushes the data (D0-D15) with the responses from the /OE and the /CE pins too. (Or in other words it's called an EEPROM emulator!)
Well, it kinda works... but it's a whole lot of mess out there:
The code was running but the screen was garbled with full of noises and artifacts running around. You can see bits of the menu and the Aaronix test screen and that's much about it.
Was the Teensy not working fast enough? Or there are wiring mistakes? Hmm... Figuring this out....
Another strange idea after a long break...
03/23/2024 at 15:16 • 0 commentsOn and off, I had been experimenting on this but with very little success.
There are too many unknowns and trying to guess how it works by modifying the code and reprogramming the flash could be too time consuming.
Later, I came up with the strange idea of connecting the vacant flash pins on the board to another microcontroller and have this microcontroller pretend it is some form of flash.
How I did that:
- Soldered the vacant flash pins with 1.27mm pitch ribbon cables (22 pins each),
- Taped the soldered wires with the Kapton. The lines on the PCB are very, very flimsy and could not tolerate a lot of movement at the solder points!
- and connect two female IDC sockets (more than 22-pins) on the other end of the wire (not shown here):
Oh, and a lot of jumper wires to connect this back to the Teensy 4.1 from the end of the female IDC connector . Here is the rough schematic (also note the white cable connected on the Reset Pin which is the "RST"):
It should be something like this in the end (pardon the mess! I will draw another cleaner diagram for this one!):
Well, all the pins are connected. Looks frustrating, and I got it done after a few weekends on this!
What would ever happen if I program the Teensy to manually feed the whole game board some instructions?
New Git found: "SUP Console Programmator"
02/23/2023 at 15:37 • 0 commentsWhen trying to find ways and means to put our custom compilation inside the flash, I bumped into this very recent article (it is in Russian - you need a Google Translate) explaining about the dumping and the flashing process of the chip inside.
Also, the author documented the rest of the process in the Github (it is in Russian too - Google Translate works on it) - it is an extremely good read.
The method would help me to dump and flash the ROM faster, and also to help me understand that program inside better.
From the article, the pictures are the attempts to build a makeshift "cartridge" that holds that flash board and the "slot" connected to the SUP console:
On that, I will try to build this too and experiment it! :)
Dump complete! Disassembling the Menu in progress...
02/23/2023 at 15:25 • 0 commentsFinally, after the one whole day it dumped the contents, I immediately used the BIN file to test it in the EmuVT 1.36. (The latest version doesn't work properly, the screen blacked out when scrolling the menu)
It just worked! Some of the games doesn't work - it could be the dumping issue, or the emulator issue. However, most of the game worked flawlessly:
(What is Utmost Warfare??? And that music... Urgh!)
Due to many, many reasons, I felt uncomfortable putting this ROM image here - since the method of dumping is possibly correct, you can replicate this process using the Raspberry Pi, a bunch of wires, and 3 MCP23017s. Here's a rough schematic:
Here is the Python code - I accidentally did a dump from 0x800000 to 0xFFFFFF, but the contents are mirrored from 0x000000 to 0x7FFFFF so the dump still worked as usual! Use a Raspberry Pi according to the schematic too.
Caution: The Python code is quite messy - it has not been finalized. This dumping process takes almost a whole day!
import time from datetime import datetime import board import busio import digitalio from adafruit_mcp230xx.mcp23017 import MCP23017 # ROM dump utility print("ROM dump utility") # Initialize the I2C bus: i2c = busio.I2C(board.SCL, board.SDA) mcp00 = MCP23017(i2c, address=0x20) mcp01 = MCP23017(i2c, address=0x21) mcp02 = MCP23017(i2c, address=0x22) # mcp00 = addr (A0-A15) [A+B] # mcp01 = addr (A16-A23) [A]; /CE, /WE, /OE [B] # mcp02 = data (D0-D15) [A+B] # setting data pins: mcp02.iodira = 0xff mcp02.iodirb = 0xff mcp02.gppua = 0x00 mcp02.gppub = 0x00 # setting address pins (A0-A15): mcp00.iodira = 0x00 mcp00.iodirb = 0x00 mcp00.gpioa = 0x00 mcp00.gpiob = 0x00 mcp00.gppua = 0x00 mcp00.gppub = 0x00 # setting address pins (A16-A23): mcp01.iodira = 0x00 mcp01.gpioa = 0x00 mcp01.gppua = 0x00 # setting control pins (/CE, /WE, /OE): # bit 0 = /CE # bit 1 = /WE # bit 2 = /OE mcp01.iodirb = 0x00 mcp01.gpiob = 0x07 pinCE = mcp01.get_pin(8) pinWE = mcp01.get_pin(9) pinOE = mcp01.get_pin(10) pinCE.switch_to_output(value=True) pinWE.switch_to_output(value=True) pinOE.switch_to_output(value=True) pinCE.pull = digitalio.Pull.UP pinWE.pull = digitalio.Pull.UP pinOE.pull = digitalio.Pull.UP pinCE.value = True pinWE.value = True pinOE.value = True def _CE(en): if (en == True): pinCE.value = False elif (en == False): pinCE.value = True else: raise Exception("True or False only!") def _OE(en): if (en == True): pinOE.value = False elif (en == False): pinOE.value = True else: raise Exception("True or False only!") def putAddr(addr): mcp00.gpioa = (addr & 0x000000ff) mcp00.gpiob = (addr & 0x0000ff00) >> 8 mcp01.gpioa = (addr & 0x00ff0000) >> 16 #print("mcp00 gpioa = " + hex(mcp00.gpioa)) #print("mcp00 gpiob = " + hex(mcp00.gpiob)) #print("mcp01 gpioa = " + hex(mcp01.gpioa)) def getData(): dataL = mcp02.gpioa dataH = mcp02.gpiob return (dataH << 8) | dataL def readAddr(addr): value = None putAddr(addr) _CE(True) #time.sleep(0.01) _OE(True) #time.sleep(0.01) value = getData() _CE(False) _OE(False) return value def dumpROM(): for addr in range(0x800000, 0xffffff,1): print("Reading block: ", hex(addr)) f.write(readAddr(addr).to_bytes(2, byteorder="little")) f = open("romdump.hex","wb") f.seek(0) # possibly read only 8 megabits! #f.write(readAddr(0).to_bytes(2, byteorder="big")) startTime = datetime.now() addr = 0 #524288 #f.write(readAddr(addr).to_bytes(2, byteorder="big")) # let's read each 2048 blocks first! dumpROM() stopTime = datetime.now() print("time taken: ", stopTime-startTime) f.close()
What's next? I'm trying to understand how the menu and the Aaronix Test screen works. I suspect this had to do a initial startup on the LCD and possibly some other peripherals.
Attempt no.2 : New information!
01/25/2023 at 12:52 • 0 commentsYes, it has been a very long time since I updated here due to the lack of information on these little things.
Previously, I have only managed to get a partial dump of the ROM - possibly only the first 8 megabytes.
However, someone on the 'net has managed to upload another schematic of the ROM carrier board - this time there's a slight variation on the A22 and A23 pin which I couldn't locate earlier:
(Thanks to the person who uploaded this - I couldn't find this link anymore!)
I took out that dumper board which I made it using the Raspberry Pi and some MCP23017s since 2020 and tried to reconnect the A22 and A23. However, the dumping is pretty slow and could take a day or so, and as a little preview I managed to see some menu cut-outs and game titles inside (I dumped from 0x80000 onwards). I believe that it has a menu in Mandarin too:
And I found a list of game using the HxD too:
Earlier in 2022, someone examined the ROM dump and uploaded it into a forum, however these dumps couldn't be downloaded, it's a broken link instead: https://4pda.to/forum/index.php?showtopic=979648&st=480:
Not only the person had dumped it but he/she had possibly get it to work using the EmuVT emulator:
Also, there are a number of videos that is showing the unit being modified to play other compilation of games:
There are no schematics provided or instructions posted in these videos, so if there are any new information on these, you can put in the comments below! :D
What a big dump! Analysis no. 1!
11/29/2020 at 06:14 • 0 commentsPardon me for that title. The dump means I dumped that 8 Megabytes worth of contents from that ROM I described earlier.
After a few more hours of dumping through Raspberry Pi and extracted its BIN file, I noticed that:- Suspected inconsistent addressing beyond 64KB
- I peeked into the original snapshot of the bootup from the bus analyzer from Analog Discovery 2:
Then, in the same fashion, I sniffed out the last 8-bit of the address from the bus analyzer:
The top 8-bit address during the bootup shows a 0x02 and 0x03 - but I couldn't find that exact bootup code from above with that higher address in the BIN file. That leads to...
- Incomplete memory dump
- This BIN sample has been analyzed by an experienced member in BGC forum: http://bootleg.games/BGC_Forum/index.php?topic=2884.0
- It is incomplete - I looked high and low for the menu cut-outs and hints of it but couldn't see them.
- Highly suspected that the last address A24 isn't accessible - it ends up mirroring whatever contents from the first 8MB.
I have another sample of this and planning to extract and see if these are the same thing or not.
