Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
ESD Generator
A test board for generating high voltages for ESD tolerance testing.
Staf VerhaegenStaf Verhaegen
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
5 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
330
0
5
4
Team (1)
  • Staf VerhaegenStaf Verhaegen
Join this project's team
  • PCB Design
ongoing project
This project was created on 10/11/2020 and last updated 2 years ago.
Description
This is a board to allows to charge a small capacitor to a few kV that then can be used to test ESD (electro-static discharge) tolerance testing on a DUT (device under test).
Purpose is a tool usable for some ESD tolerance testing without guarantee that it is usable for standard conformant ESD product qualification.
Project Logs
Collapse
  • Voltage multiplier debugged
    Staf Verhaegen • 11/02/2020 at 09:13 • 0 comments
    After some more debugging I now got the voltage multiplier working:
    https://chips4makers.io/blog/fixing-the-esd-generator.html
  • More details and first test results
    Staf Verhaegen • 10/11/2020 at 13:27 • 0 comments
    A little more background on the project can be found on this blog post.
    First test results and problems are available and are reported on in this blog.
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
A full open source electronic lab
Project Owner Contributor
Yellow pitaya
SanpiSanpi
This is a test.
This is a test
VictoriaVictoria
test
alpha beta
Shree SureshShree Suresh
In this tutorial, we are going to discuss How to make Test Points on a Printed Circuit Board (PCB)
Test Points in Printed Circuit Board (PCB)
Circuits DIYCircuits DIY
Going up?
© 2022 Hackaday
Yes, delete it Cancel
You are about to report the project "ESD Generator", please tell us the reason.
Send message
Remove Member
