Where is this heading????
A project log for Transistorless Sound Synthesizer
A home brew mini-synth idea using no transistors with the Patrick Oscillator
dr-cockroachDr. Cockroach 10/28/2020 at 21:200 Comments
October 28, 2020 -  I am at a bit of a crossroads with this project. I will continue to explore just how much I can expand the range of sounds with this oscillator but now I also want to build a multi voice drone similar to what Sam from Look Mum No Computer fame has made at https://www.lookmumnocomputer.com/
If you have a moment then check out his projects. All are Mad Good but I really love the Drone of his and I think I can make at least a 5 to 10 voice example. Check out his Megadrone https://www.lookmumnocomputer.com/projects#/1000-oscillator-megadrone
And if I make a batch of oscillators then I could have a basic and messy polyphonic system in its beginning stages.
