Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Events Hackerspaces Profiles Hackaday.com Tindie Marketplace Remoticon
Sign up Log in
nobotro os
Simple operating system with bootloader and mini kernel
misha kevlishvilimisha kevlishvili
Following Follow project
Liked Like project
Become a Hackaday.io member
Not a member? You should Sign Up.
Already have an account? Log In.
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3 comments
2 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 3
View Gallery
75
3
2
0
Team (2)
  • misha kevlishvilimisha kevlishvili
  • NoahNoah
Join this project's team
  • nobotro os
completed project
Software
C os asm nobotro os
This project was created on 10/13/2020 and last updated 3 months ago.
Description
bootloader written in asm and mini kernel in c.it has protected mode ,gdt,simple video and keyboard driver,standart c librarys.
make all -to compile
make emu-to emulate in qemu
make flash-to write os in flash drive and check in real pc(!!!warning. use formated and empty usb drive.check usb drive path in make file before flash to avoid data los.in my case usb drive is in /dev/sdb )
Details
Log In/Sign up to comment
Sign up with Github
OR
Noah wrote 10/15/2020 at 20:38 • point
i would love to be a contributor to this project! Got any room?
newblicious wrote 10/13/2020 at 20:20 • point
Very interesting. I love microkernels.
Have you shared your project on the OSdev forums?
misha kevlishvili wrote 10/14/2020 at 04:38 • point
No,didnot share to any forums
Run Windows 7 from a VHD on a NVME Drive
Project Owner Contributor
NVME Win7 VHD
Stanislas BertrandStanislas Bertrand
Press the button to momentarily disconnect a USB device
USB Interruptor
Paul StoffregenPaul Stoffregen
Follow these few steps to install Puppy Linux on a USB thumb drive
Install Puppy Linux on a USB
brucejdiibrucejdii
USB Type-C/PD Analyzer is an Open Source Hardware/Software tool that helps you test, debug and explore USB Type-C/PD Devices.
USB Type-C/USB PD Analyzer
GoArksGoArks
Going up?
© 2021 Hackaday
Yes, delete it Cancel
You are about to report the project "nobotro os", please tell us the reason.
Send message
Remove Member
