In order to reduce spam or potential bot manipulation, I implemented a rate limit on how quickly a user could submit a new color. This is done by a simple map (NodeJS) or dictionary structure (Python), and associating the last message time with a user. If that time is under the set timespan, the user is not allowed to set a color and their time value is not updated. If that time is greater than the allotted timespan, the user’s command is allowed and their time value is updated.
Edward C. Deaver, IV
