A final go at a 6 segment font
Some time after I published my experiment in a 6 segment font I decided to see if I could apply the lessons learnt and improve the font a little before closing off this line of experimentation for good.
I decided that:
- Curved segments with only a few dots were er, pointless. I decided to make all the segments straight lines. Somehow viewers are more forgiving if the lines are constrained to be straight.
- Keep the digit upright, a slant doesn't look good.
- Use symmetry.
- Close the gap in the middle, most visible in the 5 in the initial attempt.
- Implement a high-zero, which would partly compensate for the half-height zero. This was the one change that spurred me to make another attempt.
I first laid out the LED positions in KiCad and made a print of the silk screen layer of the PCB. Then I filled in the dots with a marker pen to give me a preview of how the font would look. It was promising so I went ahead and ordered 5 boards from ALLPCB.
In addition, the positions of the LEDs on the board made it possible to have a reasonable colon again, although this is not demonstrated here.
The link to the design files for the board on GitHub are in the links section.
I do think it's an improvement over my initial effort. It's too late to displace the 7-segment font, and high-resolution displays are so much more attractive wherever they can be deployed, so this is just me tinkering. I think the best I can hope for is for a futurepunk film or video to make use of this strange looking font. 🤗
